Homework Help: Moment of Inertia Questions
  1. Oct 8, 2004 #1
    **The problem and solution is attached as moment of inertia.**
    **The equations for moment of inertia of known homogeneous solids is also attached**
    I'm having some trouble grasping this concept. I hope someone can help clarify some things for me.
    Looking at the problem I realized I would have to use the parallel axis theorem, but after that the trouble begins. (I = Ig + m*d^2)
    "Deterimine the wheel's M of I about an axis perpendicular to the page and passing thru pt A."
    What does this mean? What is it saying?
    And a related question to the above: Why when calculating M of I for the thin ring (Homogeneous solids jpeg) do you use Izz = m*r^2 instead of Ixx or Iyy? Same question for the slender rod. How do you know which one to use?
    I realize I've said a lot, but I hope someone can give me some pointers.
    Thanks.
  3. Oct 8, 2004 #2
    Have you identified what the axis passing through A looks like?
    The axis A appears parallel to the z axis judging from the orientation of the second picture so yes you are correct. If you look at the orienation of the rods they are perpendicular to the A axis so judging from the second picture again you should use the y M of I.
    My personal opinion is that for simple objects like that it is easier to derive the M of I so perhaps just remembering that the M of I is in integral form (r^2dm)
