1. Not finding help here? Sign up for a free 30min tutor trial with Chegg Tutors
Moment of inertia tensor
  1. Dec 12, 2008 #1
    In Cartesian coordinate system are two point masses of mass [tex]m[/tex] connected with massless rod. Masses are in [tex](0,r,0)[/tex] and [tex](0,-r,0)[/tex].
    a) Find the moment of inertia tensor.
    b) Points were rotated in OXY plane such that angle between rod and Y-axis is [tex]\vartheta[/tex] (new cooridnates of masses are [tex](-r \sin \vartheta, r \cos \vartheta, 0)[/tex], [tex](r \sin \vartheta, -r \cos \vartheta, 0)[/tex]
    2. Relevant equations
    [tex]\hat{I} = \left(\begin{matrix}
    I_{xx} & I_{xy} & I_{xz}\\
    I_{yx} & I_{yy} & I_{yz}\\
    I_{zx} & I_{zy} & I_{zz}\\
    \end{matrix}
    \right)[/tex]
    [tex]I_{xx} = \sum _{k} m_{k} (y^{2}_{k}+z^{2}_{k}) = \sum _{k} m_{k}(r^{2}_{k} - x^{2}_{k})\![/tex]
    [tex]I_{yy} = \sum _{k} m_{k} (z^{2}_{k}+x^{2}_{k}) = \sum _{k} m_{k}(r^{2}_{k} - y^{2}_{k})\![/tex]
    [tex]I_{zz} = \sum _{k} m_{k} (x^{2}_{k}+y^{2}_{k}) = \sum _{k} m_{k}(r^{2}_{k} - z^{2}_{k})\![/tex]
    [tex]I_{xy} = I_{yx} = - \sum _{k} m_{k} x_{k}y_{k}\![/tex]
    [tex]I_{yz} = I_{zy} = - \sum _{k} m_{k} y_{k}z_{k}\![/tex]
    [tex]I_{zx} = I_{xz} = - \sum _{k} m_{k} z_{k}x_{k}\![/tex]
    3. The attempt at a solution
    a) Using relevant equations I get
    [tex]\hat{I} = \left(\begin{matrix} 2 m r^2 & 0 & -2 m r^2 \\ 0 & 4 m r^2 & 0 \\ -2mr^2 & 0 & 2mr^2 \end{matrix}\right)[/tex]
    is it correct?
    b) I'm not sure, hence I'm asking :) - is it enough (and correct) to calculate:
    [tex]\hat{I}' = \hat{I} \left(\begin{matrix} \cos \varphi & \sin \varphi & 0 \\ -\sin \varphi & \cos \varphi & 0 \\ 0 & 0 & 1 \end{matrix}\right)[/tex] or maybe [tex]\hat{I}' = \left(\begin{matrix} \cos \varphi & \sin \varphi & 0 \\ -\sin \varphi & \cos \varphi & 0 \\ 0 & 0 & 1 \end{matrix}\right) \hat{I}[/tex] or sth else?
  3. Dec 12, 2008 #2
    For a) I think there are only contributions in the top left and bottom right components.
    Using your formulae, I_xy, I_xz and I_yz are all zero as they all involve multiplying by the x or z component of either particle's position (both of which are 0). Therefore all the off-diagonal entries must be 0. I agree with you for I_11 and I_33 however - I get both to be 2mr^2. However, the middle component, I_22, must be 0 as it's the sum of the square of the z component and the square of the x component but both x and z are 0 are mentioned previously.
    To sum up, I get 2mr^2 in the top left and bottom right and 0's everywhere else.
    Hope this helps.
  4. Dec 12, 2008 #3
    b) wikipedia tells me the -ve signs should be the other way round in your rotation matrix for a rotation about the z axis (http://en.wikipedia.org/wiki/Rotation_matrix). Wikipedia calls this matrix R_z,theta, however we'll call it L. As your examining the moment of inertia tensor we need to use the transformation law for tensors:
    I'_i,j=l_i,alpha*l_j,beta*I_alpha,beta
    this implies that in terms of matrices, I'= L I L^T where L^T is the transpose of L
    Just copmute that matrix product or you could repeat the process in a) using the new coordinates but this would be a bit tedious.
    Let me know if this works. Also I'm new-ish here - how do you type in LaTeX?
  5. Dec 13, 2008 #4
    Thanks for your replay.
    But [tex]x_i[/tex] isn't x component of particle position but its distance to X-axis.
    So for example [tex]I_{xz} = -m r \cdot r - m r \cdot r = - 2 mr^2[/tex]. Only [tex]y_i = 0[/tex] because both particles lie on Y-axis.
    PS. To type in LaTeX use [tex] tags.
  6. Dec 13, 2008 #5
    Ok. Well I reckon my method for b) is still right.
    Just reading my notes. I think that I_xx is the copmonent about the x axis.
    r^2 - x^2 represents the perpendicular distance squared betweent he mass and the x axis.
    but here x^2 is just the x component.
    so y^2 + z^2 = r^2 - x^2 is just the sum of the squares of the y and z components and this represents the square of this perpendicular distance.
    To see this, consider I_yy, as you dais both particles lie on the y axis, therefore there can be no moment of inertia about this axis and so I_yy=0
  7. Dec 13, 2008 #6
    Ok, I was wrong. x_i is x component of mass position.
    But in b) I think if L is a matrix of rotation there should be [tex]I' = L^T I L[/tex].
  8. Dec 13, 2008 #7
    D H
    Staff Emeritus
    Yes, it is. Another way to look at the inertia tensor for a collection of point masses about the origin is
    [tex]\mathbf{I} = (\sum_k m_k\,r_k^2)\mathbf{1} - \sum_k m_k\,\mathbf {r}_k \mathbf {r}_k^T[/tex]
    where [itex]\mathbf{1}[/itex] is the identity matrix, [itex]k[/itex] indexes the point masses, [itex]m_k[/itex] is the mass of the kth point mass, [itex]\mathbf {r}_k[/itex] are the coordinates of the kth point mass written as a column vector, and [itex]\mathbf {r}_k \mathbf {r}_k^T[/itex] is the outer product of that vector with itself. In terms of components, the above expression becomes
    [tex]I_{ij} = \sum_k m_k(r_k^2\delta_{ij} - r_{k,i}r_{k,j})[/tex]
    latentcorpse was exactly right in post #2. The only non-zero components of the inertia tensor for part (a) are Ixx and Izz.
  9. Dec 13, 2008 #8
    Yes. You're correct here. That's what I was getting at but maybe it wasn't clear as I wasn't using LaTeX. However, in your original post, you only appear to have multiplied by one of the transormation matrices.
  10. Dec 13, 2008 #9
    Ok, thank you both! :)
Similar Discussions: Moment of inertia tensor
Loading...
