1. PF Contest - Win "Conquering the Physics GRE" book! Click Here to Enter
Moment on door vehicle
  1. Nov 20, 2009 #1
    Validity of Einstein's Elevator Experiment
    I solved the problem below using Einstein's http://en.wikipedia.org/wiki/Equivalence_principle" [Broken], or "elevator experiment," and I easily find an answer. I used traditional dynamics analysis and I get a different answer! Where is the mistake in my solution(s) or assumptions? I'm pretty good with dynamics, but I'm having trouble resolving this. Any help greatly appreciated!
    A door is hinged to a vehicle at pt. O and is open at angle [tex]\theta[/tex]. The vehicle's acceleration is a[tex]_{}o[/tex]. I need to find the moment on the door caused by the vehicle's acceleration.
    Answer from Solution 1: M = m*a[tex]_{}o[/tex]*r*sin([tex]\theta[/tex])
    Answer from Solution 2: M = a[tex]_{}o[/tex]*r*sin([tex]\theta[/tex])/(1/m+r^2/I)
    a[tex]_{}o[/tex] is the acceleration of the vehicle in the x direction.
    [tex]\theta[/tex] is the angle of the door away from the x axis towards the y axis.
    m is the mass of the door.
    r is the distance from the hinge to the door's center of mass.
    I is the door's moment of inertia.
    Based on my interpretation of Einstein's "elevator experiment" or "equivalence principle," instead of saying that the vehicle is accelerating, I can say that the vehicle is stationary with the door being exposed to a gravity field in the -x direction with magnitude a[tex]_{}o[/tex]. This makes it a very easy pendulum problem.
    Force is applied at center of gravity
    F = m*a[tex]_{}o[/tex]
    Moment is force times moment arm
    M = F*r*sin([tex]\theta[/tex])
    I know that the vehicle pushes on the door at pt. O (but I don't know magnitude or direction):
    F = force vector applied to pt. O
    F has magnitude f in the [tex]\theta[/tex]F direction. To see what this force does to the door, I move F to the center of gravity (pt. cg). The moment caused by moving this vector is:
    M = R x F
    R is the vector from pt. cg to pt. O. "x" is the cross product.
    Now I know how the body will move for a given force vector.
    A_CG = F/m
    ALPHA = M/I
    ALPHA is the radial acceleration vector, and A_CG is the acceleration vector of pt. cg.
    I want to figure out what force vector will cause the door to move such that the hinge point accelerates in the x direction with magnitude a[tex]_{}o[/tex]. I can then calculate the moment.
    To find acceleration of pt. O:
    A_O = A_CG + OMEGA x ( OMEGA x R ) + ALPHA x R
    My vectors ([x,y,z]' indicates a column vector):
    OMEGA = omega*[0,0,1]'
    R = r*[-cos([tex]\theta[/tex]),-sin([tex]\theta[/tex]),0]'
    F = f*[cos([tex]\theta[/tex]F),sin([tex]\theta[/tex]F),0]'
    ALPHA = M/I = 1/I * R X F
    From here out I'll use:
    c[tex]\theta[/tex] = cos([tex]\theta[/tex]), st = sin([tex]\theta[/tex])
    c[tex]\theta[/tex]f = cos([tex]\theta[/tex]F), stf = sin([tex]\theta[/tex]F)
    My x direction and y direction equations come out to:
    a[tex]_{}o[/tex] = f/m*c[tex]\theta[/tex]f + omega^2*r*c[tex]\theta[/tex] - r^2*f/I*s[tex]\theta[/tex]*(c[tex]\theta[/tex]*s[tex]\theta[/tex]f-s[tex]\theta[/tex]*c[tex]\theta[/tex]f)
    0 = f/m*s[tex]\theta[/tex]f + omega^2*r*s[tex]\theta[/tex] + r^2*f/I*c[tex]\theta[/tex]*(c[tex]\theta[/tex]*s[tex]\theta[/tex]f-s[tex]\theta[/tex]*c[tex]\theta[/tex]f)
    I can combine the two equations to get rid of the omega^2*r terms. Divide the first equation by c[tex]\theta[/tex] then subtract the second equation divided by s[tex]\theta[/tex].
    a[tex]_{}o[/tex]/c[tex]\theta[/tex] = f/m*(c[tex]\theta[/tex]f/c[tex]\theta[/tex]-s[tex]\theta[/tex]f/s[tex]\theta[/tex]) + r^2*f/I*(c[tex]\theta[/tex]*s[tex]\theta[/tex]f-s[tex]\theta[/tex]*c[tex]\theta[/tex]f)*(-s[tex]\theta[/tex]/c[tex]\theta[/tex]-c[tex]\theta[/tex]/s[tex]\theta[/tex])
    Multiply both sides by st*ct
    a[tex]_{}o[/tex]*s[tex]\theta[/tex] = f/m*(s[tex]\theta[/tex]*c[tex]\theta[/tex]f-c[tex]\theta[/tex]*s[tex]\theta[/tex]f) + r^2*f/I*(s[tex]\theta[/tex]*c[tex]\theta[/tex]f-c[tex]\theta[/tex]*s[tex]\theta[/tex]f)
    a[tex]_{}o[/tex]*s[tex]\theta[/tex] = f*(s[tex]\theta[/tex]*c[tex]\theta[/tex]f-c[tex]\theta[/tex]*s[tex]\theta[/tex]f)*(1/m+r^2/I)
    f = a[tex]_{}o[/tex]*s[tex]\theta[/tex]/((s[tex]\theta[/tex]*c[tex]\theta[/tex]f-c[tex]\theta[/tex]*s[tex]\theta[/tex]f)*(1/m+r^2/I))
    M = R x F = r*f*(s[tex]\theta[/tex]*c[tex]\theta[/tex]f-c[tex]\theta[/tex]*s[tex]\theta[/tex]f) (magnitude of M)
Draft saved Draft deleted
Similar Threads - Moment door vehicle Date
I Moment of Inertia of a Disc Jan 4, 2018
I Relationship between magnetic moment and induced magnetism Nov 7, 2017
A Moment of Inertia Tensor Oct 20, 2017
