Calculating Upward Contact Forces of Uniform Ladder
  • Thread starter m3trj
  • Tags
    Moments
In summary, the two men carrying a 12m ladder exert upward contact forces of 110N and 140N. To calculate these forces, the moments of forces must cancel around any one point. The man closer to the front, "A", exerts a force of 111.111...N while the man closer to the back, "B", exerts a force of 140N. These forces add up to the weight of the ladder, 250N.
m3trj
I found the following question in a textbook:
Two men are carrying a uniform ladder of length 12m and weight 250N. One man holds the ladder 2.0m from the front end and the other man is 1.0m from the back of the ladder.
Calculate the upward contact forces that each man exerts on the ladder.
The answer section in the textbook says the forces are 110N and 140N. But how do you go about calculating that? I really need an explanation as I just don't understand. I can see the forces add up to 250N, but I'm not sure how to calculate each force. Maybe I'm just dumb.
Any help would be greatly appreciated.
The moments of forces must cancel about anyone point as well.
Let us call the man near the front "A", who exerts a force [tex]F_{A}[/tex] on the ladder a distance 4m from the centre of the ladder.
Let us call the man near the front "B", who exerts a force [tex]F_{B}[/tex] on the ladder a distance 5m from the centre of the ladder.
Thus, we must have:
[tex]4F_{A}-5F_{B}=0\to{F}_{A}=\frac{5}{4}F_{B}[/tex]
We also have that the sum of forces acting on the ladder must be zero:
[tex]F_{A}+F_{B}-250=0[/tex]
Thus, [tex]\frac{9}{4}F_{B}=250\to{F}_{B}=\frac{1000}{9}=111.111...\approx110[/tex]
Got it?
Hello,
First of all, don't worry, you are not dumb! Calculating forces can be tricky and it takes practice to fully understand it.
Let's break down the problem step by step:
1. Draw a free body diagram: This is a diagram that shows all the forces acting on an object. In this case, the ladder is the object and we need to show the forces acting on it. Draw a straight line to represent the ladder and label the front and back ends as F1 and F2 respectively. Also, label the weight of the ladder (250N) acting downwards at the center of the ladder.
2. Identify the forces: In this problem, there are two forces acting on the ladder - the weight of the ladder (250N) and the upward contact forces exerted by the two men. The force exerted by the man at the front of the ladder (F1) is directed upwards and the force exerted by the man at the back of the ladder (F2) is also directed upwards.
3. Apply Newton's Second Law: This law states that the net force acting on an object is equal to the mass of the object multiplied by its acceleration. In this case, the ladder is not accelerating, so the net force acting on it is zero. This means that the sum of all the forces acting on the ladder must be equal to zero.
4. Set up equations: We can set up two equations to represent the forces acting on the ladder - one for the x-direction and one for the y-direction. In the x-direction, the only force acting is F1, so the equation is F1 = 0. In the y-direction, the equation is F1 + F2 - 250N = 0.
5. Solve for the unknowns: We have two equations and two unknowns (F1 and F2). We can solve for F1 in the first equation and substitute it into the second equation. This gives us F2 - 250N = 0. Rearranging the equation, we get F2 = 250N. This means that the force exerted by the man at the back of the ladder (F2) is equal to 250N.
6. Substitute back: Now that we know the value of F2, we can substitute it back into the first equation to solve for F1. This gives us F1 = 0. This means that the force exerted
1. How do you calculate the upward contact force of a uniform ladder?
The upward contact force of a uniform ladder can be calculated by using the equation F = W(sinθ + μcosθ), where F is the upward contact force, W is the weight of the ladder, θ is the angle of inclination, and μ is the coefficient of friction.
2. What is the coefficient of friction and how does it affect the calculation of upward contact force?
The coefficient of friction is a measure of the resistance between two surfaces in contact. It affects the calculation of upward contact force by determining how much frictional force is present between the ladder and the surface it is resting on. A higher coefficient of friction will result in a greater upward contact force.
3. Can the angle of inclination affect the calculation of upward contact force?
Yes, the angle of inclination does affect the calculation of upward contact force. As the angle increases, the weight of the ladder will exert more force in the upward direction, resulting in a greater upward contact force.
4. What units should be used when calculating upward contact force?
When calculating upward contact force, the weight of the ladder should be in units of force (such as Newtons or pounds) and the angle of inclination should be in degrees.
5. Are there any safety considerations to keep in mind when calculating upward contact force of a uniform ladder?
Yes, it is important to make sure that the calculated upward contact force is within the weight-bearing capacity of the surface the ladder is resting on. If the calculated force is greater than the weight-bearing capacity, it is not safe to use the ladder in that location.
