Moments of a Ladder Propped Up Against A Wall
In summary: The ladder doesn't turn, so the second way is a bit easier.In summary, the conversation discusses the formation of an equation by taking moments in a scenario involving a uniform ladder resting against a wall on rough ground. The ladder's weight and reaction from the ground are taken into consideration and the correct equation is determined by equating the moments in equilibrium. The correct equation is formulated by equating the clockwise and anticlockwise moments, or by equating the sum of moments to 0.
Priyadarshini
191
A uniform ladder rests against a vertical wall where there is negligible friction. The bottom of the ladder rests on rough ground where there is friction. The top of the ladder is at a height h above the ground and the foot of the ladder is at a distance 2a from the wall. The diagram shows the forces that act on the ladder.
Which equation is formed by taking moments?
(A) Wa + Fh = 2Wa
(B) Fa + Wa = F h
(C) Wa + 2Wa = Fh
(D) Wa – 2Wa = 2Fh
moment=F x perpendicular distance
Should the answer be (C)?
The anticlockwise moments are Wa and 2Wa and the clockwise moment is Fh, so they should be equated.
But which is the pivot? Is the pivot one of the ends of the ladder or some other point on the ladder. Shouldn't the forces have to be split into components because the force and distance must be perpendicular to each other. And shouldn't the distance be taken along the length of the ladder and not the ground?
(A) Wa + Fh = 2Wa
(B) Fa + Wa = F h
(C) Wa + 2Wa = Fh
(D) Wa – 2Wa = 2Fh
You're right,C can be an option if moments are taken about the topmost point of ladder.
About the pivot,I'm not sure what you mean.
The force should be split into components and we should then take the component which is perpendicular to the distance.But,in this situation,the forces and the distances given are perpendicular to each other already.Hence,we don't need to break up the force into components.
And if you take distance along the ladder you will also have to take the components of the forces perpendicular to this distance.By a bit of trigonometry you'll see that this will give you the same result as the one you got earlier.
The answer given is (A)
Around which point is the ladder going to rotate? Around the centre of gravity or does it rotate around one of the ends of the ladder? Where is the hinge of the turning effect located?
Priyadarshini said:
Should the answer be (C) [Wa + 2Wa = Fh]? The anticlockwise moments are Wa and 2Wa
No. Those two moments are only in the same sense if you pick an axis between the two forces. But then the distances a and 2a will not both be right.
Taking an axis at the base of the wall, the ladder's weight has a clockwise moment and the reaction from the ground has an anticlockwise moment.
But why are they adding the clockwise and anticlockwise moments? How did they get 2Wa on the right hand side of the equation?
Shouldn't you equate the two moments as the ladder does not turn and is in equilibrium?
In equation C? To produce a deliberately incorrect equation.
You can either write ##\Sigma## clockwise moments = ##\Sigma## anticlockwise moments, or write ##\Sigma## moments = 0, where each moment is given a sign according to its sense.
No, in option (a), the clockwise moments have been added to the anticlockwise moments to get 2Wa. Wa is the clockwise moment and Fh is the anticlockwise moment, but what is 2Wa?
No, they haven't done that.
They have not stated what axis they are taking moments about in each case. You have to try to find an axis for which the equation is correct.
How might a force W produce a moment 2Wa?
Is the axis here then along the W force that acts upwards?
But how do we figure out where the axis is if there are no options and if it was a written question?
In the diagram, there are two forces magnitude F and two magnitude W.
In equation A, there are moments Wa, 2Wa and Fh.
Clearly the Fh moment must be a result of one of the two F forces and the other F force has no moment. This leaves only two possibilities for the Y coordinate of the axis. What are they?
Similarly, to get those two moments from the two W forces, there are only two possible values for the X coordinate of the axis.
Finally, see if any of those four X, Y combinations give the right signs.
Edit: That said, it's probably quicker just to pick a fairly obvious axis, work out the balance of moments equation for yourself, and see if it can be manipulated to match one of the given equations.
The F that acts along the horizontal at the base of the ladder has no moments. So the two possibilities for the Y coordinate of the axis is along the point on the ladder where its weight acts (W) or through the foot of the ladder where there is a force of W.
And the X coordinate acts either through F (the one at the upper tip of the ladder) or through the centre where its weight acts.
So the axis of rotation is through the W in the middle of the ladder?
But then where does 2Wa come from?
That is only true if you pick an axis somewhere along that horizontal line.
If you pick an axis at the middle of the ladder the weight will have no moment, so there will only be one W term in the equation.
Seems like you do not know how to take moments. Let's try a specific example. Suppose you pick the point where the floor meets the wall. For each of the four forces, how far is its line of action from that point? What four moments do they result in?
For the ladder, I think I understand how it works.
For the example, the forces acting is the weight of the ladder acting downwards and the normal reaction force that acts upwards, friction acts at the point and the other force is opposing this, right?
How about considering the origin (say, vertical is y-axis and horizontal is x axis) as the point of rotation of the rod?
Clearly :
1. The force acting horizontally at the ground will not produce any moment.
2. The force at the height h will produce moment Fh in clockwise direction.
3. The weight acting at the center of the ladder will produce moment Wa in clockwise direction.
4. The weight acting at the end of the rod will produce moment W(2a) in anti-clockwise direction.
You can deduce the result from here, right?
And for how to solve such questions - Always prefer to imagine the situation and taking the origin as the pivot point and try to deduce equations accordingly. You can also try to work out by taking other points as the point of rotation and see the difference in the result.
Yes, those are the forces, but what moments do they exert about the point where the floor meets the wall?
Let's just start with one: what moment does the normal reaction from the floor have about that point, and in what direction?
The moment is zero as the normal force acts at the point, so the perpendicular distance is zero.
Clearly :
Thank you!
No, the normal force from the floor acts where the ladder meets the floor. The point I specified is where the wall meets the floor. Did you misread my question?
Are the moments Fh, Wa and 2Wa?
Yes. Which ones act which way?
Fh and Wa act in the clockwise direction and 2Wa acts in the anticlockwise direction.
Right. So which equation does that match?
Option (A)! Thank you!
1. What is a moment of a ladder?
A moment of a ladder is the force generated at the base of the ladder due to the weight and position of the ladder. It is a measure of the rotational force that the ladder exerts on the wall.
2. How is the moment of a ladder calculated?
The moment of a ladder can be calculated by multiplying the weight of the ladder by the distance from the base to the point where the ladder contacts the wall. This distance is also known as the lever arm or moment arm.
3. Why is it important to consider the moment of a ladder?
Considering the moment of a ladder is important because it helps determine the stability of the ladder and whether it is safe to use. If the moment is too high, it can cause the ladder to tip over, potentially leading to injuries.
4. How does the angle of the ladder affect the moment?
The angle of the ladder has a direct effect on the moment. As the angle increases, the moment also increases, making the ladder less stable. It is important to ensure that the ladder is at a safe angle to avoid a high moment and potential tipping.
5. What are some ways to reduce the moment of a ladder?
There are a few ways to reduce the moment of a ladder. One way is to decrease the weight of the ladder itself. Another way is to increase the distance between the base of the ladder and the wall. Additionally, making sure the ladder is placed on a stable and level surface can also help reduce the moment.
