Moments of a random walk
  • Thread starter humenghu
Main Question or Discussion Point
Hi, can someone who is familiar with the analysis of random walks (statistical mechanics, condensed matter physics etc.) help me on solving a particular problem?
We define the following random walk, the random variable w(t) is evolved as
w(t+1)=w(t), with probability of p;
w(t+1)=w(t)+C*(1-w(t))*f, with probability 1-p.
C is a constant, f is a random variable with known distribution, and f is not correlated with w.
Following the way of analyzing a Brownian motion, what I have tried is to write down
E(w(t)|w(t-1),p), then show the E(w(t)|p) using the induction, for a given w(0).
Next, at least I need to find the Var(w(t)) , or equivalently E(w(t)^2) since I have known (E(w(t)))^2 for a given w(0).
I hope that someone can help me find the moment generating function of this random walk
(E(w(t)^n)), or alternatively just the mean and the variance of w(t). Any hint on this is badly needed.
Answers and Replies
haruspex
Insights Author
5,592
You can obtain E(w(t)) as something of the form A+Bλt, right?
You should also get a recurrence relation on E(w(t)2) which involves E(w(t)). This should have a solution like C+Dλt+Eμt.
Plugging in the coefficients from the recurrence relations and the initial conditions should allow you to determine the 7 constants.
Thanks for the hint.
Yeah the E(W[itex]_{n}[/itex])=K[itex]^{n}[/itex]W[itex]_{0}[/itex]+K[itex]^{n-1}[/itex]L+K[itex]^{n-2}[/itex]L+...+KL+L
Where K=p-C(1-p)E(f), L=C(1-p)E(f).
However I found that the E(Wt[itex]^{2}[/itex]) is a little bit hard to show since the terms grow somehow fast with n. I could write down:
E(W[itex]_{n}[/itex][itex]^{2}[/itex])=A[itex]^{n-1}[/itex]M+ A[itex]^{n-2}[/itex][BE(W[itex]_{1}[/itex])+C]+ A[itex]^{n-3}[/itex][BE(W[itex]_{2}[/itex])+C]+...A[BE(W[itex]_{n-2}[/itex])+C]+[BE(W[itex]_{n-1}[/itex])+C]
where A,B,C are terms consisting of p, C and random variable f.M=AE(W[itex]_{0}[/itex][itex]^{2}[/itex])+BE(W[itex]_{0}[/itex])+C
so do you think this is what you meant? or?
Addtionally I am still curious about the moments of the Wt, in a general sense. Is it possible to show them in closed form here?
haruspex
Insights Author
5,592
I don't think it should be that bad.
= K[itex]^{n}[/itex]W[itex]_{0}[/itex]+L(K[itex]^n[/itex]-1)/(K-1)
= K[itex]^{n}[/itex](W[itex]_{0}[/itex]+L/(K-1))-L/(K-1)
So as I said, it is possible to represent the first moment as A+BKn, and the second moment will have only two additional constants.
Now I see what you mean. Thanks a lot!
Did you magically predict the first two moments just by looking at the evolution rules? or did you actually write down the terms like I did, any additional tips on this ?
haruspex
Insights Author
5,592
I wrote out the recurrence relation for w(t) and saw it took the form
w(t+1) = Aw(t) + B.
Clearly this is basically multiplying by A at each step, so the answer will be something with At. To cover the inhomogeneous term (the B), look for a stationary value, i.e. w(t+1) = w(t) = w:
w = Aw+B
w = B/(1-A)
So now we have a general solution of w(t+1) = Aw(t), and a specific solution of w(t+1) = Aw(t) + B. Since the relationship is linear, we can add any multiple of the homogeneous solution to the inhomogeneous one:
w(t) = cAt + B/(1-A)
The recurrence relation for w2 is of the form
w2(t+1) = Dw2(t) + Ew(t) + F
= Dw2(t) + E(cAt + B/(1-A)) + F
Collecting up constants, this reduces to
w2(t+1) = Dw2(t) + E'At + F'
Again, the homogeneous part gives w2(t) = gDt. What to do with E'At? Iterating the recurrence will result in adding terms like that for successive values of t, i.e. the sum of a geometric series. So we know this will add a term like At to the answer. So just assume an answer of the form gDt + hAt + k, plug it into the recurrence relation and initial conditions, and see what you get for g, h and k.
I see. Thanks!
Related Threads on Moments of a random walk
  • Last Post
  • Last Post
  • Last Post
19K
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
14K
  • Last Post
