Moments of Inertia Trouble
  1. Nov 22, 2015 #1
    Attached in a picture!
    2. Relevant equations
    I = mr^2
    m = (x*y)
    cm = (x/2, y/2)
    3. The attempt at a solution
    I was able to solve Part 1 fairly fast, but Part II has drawn a blank for me overall. I was thinking of that rotational thing from Calculus where you spin a 2D figure around the axis to make a 3D shape, but I'm really just not sure. To be honest, I'm having a very difficult time even understanding the concept of moment of inertia >.< So even if I somehow guessed how to do part II right, I really don't know what I'm doing in that section.
    I) mass 1 = (20 cm)(10 cm) = 200 cm^2
    mass 2 = (10 cm)(20 cm) = 200 cm^2
    center of mass 1 = (20 cm i, 5 cm j)
    center of mass 2 = (5 cm i, 10 cm j)
    Center of Mass = (summation of (mass)(coordinates) / summation of masses) = [density of object*(200*(20 i + 5 j))+(200*(5 i + 10 j)] / density of object*(200 + 200)
    = (4000 i + 1000 j + 1000 i + 2000 j) / 400
    = 12.5 cm i + 7.5 cm j
    II) total mass of object = 4 kg
    I = summation of mass*r^2
    = (1 kg*100 cm^2)+(3 kg*300 cm^2)
    =(100 kgcm^2)+(900 kgcm^2) = 1,000 kgcm^2
    Thank you for any help and have a nice day! :-)
  3. Nov 22, 2015 #2
    Doc Al
    Staff: Mentor
    This is the moment of inertia of a point mass, not an extended object.
    Hint: Can you find the moment of inertia of a rod rotating about one end?
    Read this: Moment of Inertia
  4. Nov 22, 2015 #3
    Oh okay, so I should be using 1/3*mr^2?
  5. Nov 22, 2015 #4
    Doc Al
    Staff: Mentor
    Sure, if you use it correctly. Do you understand that the MOI of a plate about one edge is the same as that of a rod about one end?
  6. Nov 22, 2015 #5
    I didn't know that, but I would suppose so since the area-of-force on the object is going to be farther from the center of mass for both a plate and a rod. It'd be higher than if the point of force was closer to the center of mass.
  7. Nov 22, 2015 #6
    Doc Al
    Staff: Mentor
    Moving mass parallel to the axis of rotation will not affect the moment of inertia about that axis. So you can squeeze the mass of the plate into a rod and get the same MOI.
  8. Nov 22, 2015 #7
    Oh okay. I think I confused center of mass and axis of rotation there.
    So for this problem, would I be splitting the equation into two rods spinning about the y axis, and then add it all up, since the top square would be parallel to the bottom rectangle?
  9. Nov 22, 2015 #8
    Doc Al
    Staff: Mentor
    Yes. That's just what I would do.
  10. Nov 22, 2015 #9
    ah so would this be right?
    I = summation of (1/3) mass*r^2
    = (1/3)(1 kg*100 cm^2) + (1/3) (3 kg*900 cm^2)
    =(100/3 kgcm^2)+(900 kgcm^2) = 933.333333 kgcm^2 = 933 kgcm^2
  11. Nov 22, 2015 #10
    Doc Al
    Staff: Mentor
    Looks good. But I would first convert the distances to standard units (meters instead of cm).
  12. Nov 22, 2015 #11
    ah okay, 0.093 kgm^2
    and rotational inertia is different for different objects, right? Should I just memorize those formulas?
    thank you so much!
  13. Nov 22, 2015 #12
    SteamKing
    Staff Emeritus
    There are formulas for the MOI for different objects. These formulas can be derived using calculus. Most people keep a table of these formulas handy:
    https://en.wikipedia.org/wiki/List_of_moments_of_inertia
  14. Nov 22, 2015 #13
    Doc Al
    Staff: Mentor
    Sure.
    It's a good idea to have a few basic ones memorized... just in case. If you have a bit of calculus under your belt, be sure to understand how they are derived.
Have something to add?
Draft saved Draft deleted
Similar Discussions: Moments of Inertia Trouble
  1. Moment of inertia (Replies: 3)
  2. Moment of inertia (Replies: 2)
  3. Moment of Inertia (Replies: 2)
Loading...
