Momentum and Angles
  1. Nov 16, 2009 #1
    A golf ball of mass 0.045 kg is moving in the +x-direction with a speed of 6.10 m/s, and a baseball of mass 0.145 kg is moving in the -y-direction with a speed of 2.20 m/s. What are the magnitude and direction of the total momentum of the system consisting of the two balls?
    _________kg·m/s
    _________° (from the +x axis)
    2. Relevant equations
    P=mv and I'm not sure what else...
    3. The attempt at a solution
    My teacher said that we should be able to teach ourselves momentum, so as one might be able to tell, I'm not sure where to start.
    I tried doing (.045x6.1) + (.145x2.2) = P, but that didn't work. How should I start? Are there other equations I should know?
    Thank you so much for your help!
  3. Nov 16, 2009 #2
    Did you learn about center of mass? I'm sure your textbook probably has a section on it. The momentum of the system is the same as the momentum of the center of mass of the system.
  4. Nov 17, 2009 #3
    Redbelly98
    Staff Emeritus
    Momentum is a vector, with the same direction as the velocity of the object. You need to add the two momenta as vectors; don't simply add (.045x6.1)+(.145x2.2).
  5. Nov 18, 2009 #4
    I just solved it, thank you everyone!
    (I did pythagorean theorum and for the angle I just did tangent!)
Similar Discussions: Momentum and Angles
  1. Momentum with an angle (Replies: 8)
Loading...
