Momentum and Speed Relativity in a Moving Reference Frame
In summary, Jennifer runs 5.1m/s towards the right end of a cart that has a speed of 5.10m/s. When she reaches the end of the cart, she has traveled 2.46m.
Yousufshad
28
Jennifer (mass 60.0kg) is standing at the left end of a 14.0m long 538.0kg cart that has frictionless wheels and rolls on a frictionless track. Initially both Jennifer and the cart are at rest. Suddenly, Jennifer starts running along the cart at a speed of 5.10m/s relative to the cart. How far will Jennifer have run relative to the ground when she reaches the right end of the cart?
momentum = mv
p is momentum
Pi = 0 so
60*5.1 = 538v
v=0.568m/s velocity of cart
14m of cart takes her t(5.668m/s) = 14
t=2.46s
I'm confused about this relativity, do i use velocity of 5.1 when calculating conservation of momentum ? or is is speed relative to ground?
How do i get to a number in meters relative to the ground that she ran?
The initial momentum of Jenifer and cart is zero and will remain zero since there are no external forces.
Now you have the two velocities in that (ground) frame.
Then you can find the velocity of Jenifer to the ground by simple vector addition.
Likes Yousufshad
You might ask yourself this: does it matter how fast she runs?
Likes Yousufshad
Ok so relative to the ground she is traveling at 5.1m/s - 0.568m/s = 4.523m/s
4.532m/s * 2.46s = 11.148m
This is also an incorrect answer.
I looked over my math and it all looks good, am I missing anything to consider?
I would think so, no?
If she travels slower the cart would also travel slower, so I guess not then?
How could I implement this mathematically I feel a bit stuck here.
First, can you give a good argument why the speed doesn't matter?
In any case a hint is to think more directly about distances (rather than thinking about speeds).
Well since the net momentum is 0 and she increases her speed the speed of the cart would increase to cancel the momentum change
Since we are talking about distances traveled relative to the ground her speed relative to the carts are irrelevant.
Proof: Using her speed of 5.1m/s relative to the cart I find that it takes her 2.46s to reach the end of the cart
Using her speed as 10m/s I find it takes her 1.26s to reach the end of the cart
Using vector addition I find the first case the displacement relative to the ground is 11.148m
Using vector addition I find the second case the displacement relative to the ground is 11.12m
?? So something here must be going wrong
Momentum of the system is 0, relative to the ground. If her speed is ##v## and the cart's speed is ##V## (relative to the ground), then by conservation of momentum:
##mv## = ##MV## (where ##m## is Jennifer's mass and ##M## is the cart's).
Can you do something with that?
Yeah, I believe i used that here earlier to calculate the speed of the cart with the given speed of jennifer
Pi = 0 so
60*5.1 = 538v
v=0.568m/s velocity of cart"
Pi = 0 so
60*5.1 = 538v
I don't like all these numbers. Numbers obscure what's going on.
Also, if you work in symbols, you would actually see when solving this problem that ##v## does not matter, and that would teach you a lot about the Physics.
Go back to:
##mv = MV##
Forget the ##5.1m/s##, which is irrelevant and think about the distances traveled (relative to the ground). Note that ##v## is the speed relative to the ground, not the cart, so you don't know ##v## or ##V##.
Hint: let ##d## and ##D## be the distances traveled (relative to the ground) of J and the cart respectively.
Go back to:
##mv = MV##
Okay
mv=MV
This is conservation of momentum, I know m= 60 M = 538
I only have one equation here trying to poke at two unknowns is there another formula I can pull out somewhere using v=5.1m/s relative to the ground?
Yousufshad said:
Okay
mv=MV
Let me help:
##d = vt## and ##D = Vt##
Can you use this to relate ##d## and ##D##?
Where did you get 2.46 seconds?
If she runs at 5.1 m/s on a 14 m cart, how long does it take to get to the end of the cart?
PeroK said:
Let me help:
I'm not 100% sure but is it d/v = D/V ?
Yes, but we don't know ##v## and ##V##, but we do know ##m## and ##M##.
There's too many equations being thrown around I'm getting very lost, how could I even relate m to v and M to V throuhg d/v = D/V
Okay. Maybe you want to follow J Hann's suggestion? The problem is that if you just plug numbers into equations, you don't learn much about Physics and, as you've found, one mistake in your calculations and it's very hard to spot.
To give you the next step in any case:
##md = mvt = MVt = MD##
So, not only are the speeds related simply by the relative mass, but the distances traveled (by J and cart) are related in the same way by their relative mass. And that is ... Physics!
Also, this applies to any motion (not just constant velocity): J could walk, speed up, go backwards, go at any variable speed she likes and, at all times:
##md = MD## (relative to the ground)
Whats confusing me is we started from
And are getting to md = mvt = MVt = MD
and I have no clue where you got these letters from and what they represent and how you kind of just pulled them out of your pocket.
Walk me through it using letters if you can maybe ill understand.
##m## is Jennifer's mass; ##M## is the mass of the cart; ##d## is the distance traveled by Jennifer (relative to the ground); and ##D## is the distance traveled by the cart (relative to the ground).
Okay, and now I am confused on how you figured out that
md = mvt = MVt = MD
how do i know this is true? Where would i be able to pull this formula from?
md = mvt = MVt = MD
I've shown it above using conservation of momentum. At all times, Jennifer's speed is (M/m) times the cart's speed, so the distance traveled by Jennifer (at any time) must be (M/m) times the distance traveled by the cart.
Likes Yousufshad
yes unfortunatly I am not understanding this, thanks for the help though ! :)
Okay, I'm going offline now anyway.
I looked at your numbers in your solution, but I don't see how you got them. You probably need to show how you calculated things. For example:
This isn't correct.
In fact, you probably need to consider velocities relative to the ground even in your solution!
momentum = mv
p is momentum
Pi = 0 so
60*5.1 = 538v
When you say this is the velocity of the cart, you presumably mean it's the velocity of the cart relative to the ground, right? In other words, you're working in the reference frame where the ground is at rest. If that's the case, then you need to use the velocity of Jennifer relative to the ground on the lefthand side of the equation. That's not equal to 5.1 m/s, is it?
Yeah sorry, I got it eventually, that was a tough question.
1. What is momentum and speed relativity?
Momentum and speed relativity is the concept that the momentum and speed of an object can change depending on the observer's frame of reference. This means that the measurements of an object's momentum and speed can vary depending on the relative motion between the observer and the object.
2. How is momentum and speed relativity related to Einstein's theory of relativity?
Einstein's theory of relativity states that the laws of physics are the same for all observers, regardless of their relative motion. This includes the concept of momentum and speed relativity, as the measurement of an object's momentum and speed can vary depending on the observer's frame of reference.
3. Can an object have different momentum and speed in different frames of reference?
Yes, an object's momentum and speed can appear different in different frames of reference. For example, a car may be traveling at 60 miles per hour in one frame of reference, but in a different frame of reference where the observer is also moving, the car's speed may appear to be 50 miles per hour.
4. How does the principle of conservation of momentum apply to momentum and speed relativity?
The principle of conservation of momentum still applies to momentum and speed relativity. This means that the total momentum of a closed system remains constant, regardless of the relative motion between the observers and the objects within the system.
5. What are some real-life applications of momentum and speed relativity?
Momentum and speed relativity has many real-life applications, such as in the field of particle physics where the momentum of subatomic particles is measured in different frames of reference. It is also important in space travel, where the relative motion between objects can affect their trajectories and speeds.
