Momentum conservation
In the pictures
Fnet = dp/dt
I know in part b there is a net external force (gravity) that does positive work, fnet > 0, thus dp/dt is positive. Does the spring in part c increase or decrease the momentum of the system? I am not too sure of
my answer.[/B]
Answers and Replies
176
What is 'the system?' Is it both blocks or one block? Do you see how the answer is different in either case?
The system consists of the two gliders. So it appears that the spring is indeed an external force. But the direction the spring accelerates the block is in negative direction, so I am not sure how the TOTAL momentum of the system will change.
haruspex
Insights Author
2020 Award
36,804
7,132
Even if you count the spring as external to the system (and I'm not sure that's intended), you are not given any mass for it. Taking its mass as zero, it cannot add or remove any momentum from the system of gliders.
Related Threads on Momentum conservation
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
