Discover the Recoil Speed of a Cannon at the Circus - Momentum Formula Help
In summary, the first conversation discusses the concept of recoil speed and the formula for finding momentum. The second conversation involves two identical carts attached by a cord, and the question is how to find the speed of one cart after the cord is cut using the concept of conservation of momentum.
MIA6
233
1. At the circus, a 100 kilogram clown is fired at 15 meters per second from a 500 kilogram cannon. What is the recoil speed of the cannon? My question is what does 'recoil speed' mean? that's it.
2. There are two identical carts, attached by a cord moving to the right at speed V. If the cord is cut, what would be the speed of cart A? Just imagine that there are two carts, and between them there is a cord attached to each other, and i think this cord moves to the right at the speed of V. How can i find cart A, what formula can i use? momentum?
thanks.
1. The recoil speed is how fast the cannon will move in the opposite direction after the blast.
2.Yes, momentum will work for this problem.
but which formula of momentum does it relate to the question? change in momentum, as in impulse? or conservation of momentum? Can you sort of give me some ideas, i really don't understand it.
Heres my 2 cents about the 2nd question.
If the two cars are connected with a cord (such that the first car is pulled by the second), then consider their mass to be say "m", and since the two cards are identical, they have the same mass.
Find the momentum of the whole system, i.e. MV. Where M is the sum of the masses of individual cars i.e. 2m. And the total velocity of the system is given (V). If the cord is cut, the cars are no longer attached. But by conservation of momentum, the sum of their individual momentums should be equal to the total momentum of the system. I hope this helps.
Regards,
Sleek.
so i use this formula: m1v1i+m2v2i=m1v1f+m2v2f? what's the initial velocity?
The clown and cannon start at rest. It is an impulse and the time is the same for the clown and cannon.
Equal and opposite force. Equal and opposite momentum.
I meant the second question about the cord.
You start with both objects as part of a bigger object at some speed,V. The total mass will be the mass of the two carts, or 2m, since the carts are identical. So, you start with on object, whose momentum is , p=2mV, and end with 2, whose momenta are: p_A=mv_A and p_B=mv_B.
The big hint here is that the carts are identical and moving at the same speed. If you think about this, it should make the problem much easier.
1. What is the formula for calculating momentum?
The formula for momentum is p = m * v, where p is momentum, m is mass, and v is velocity.
2. How is momentum different from velocity?
Momentum is a measure of an object's mass and velocity combined, while velocity only measures the speed and direction of an object.
3. What are the units of momentum?
Momentum is measured in kilograms * meters per second or kg * m/s.
4. Can momentum be negative?
Yes, momentum can be negative if the object is moving in the opposite direction of its velocity.
5. How is momentum conserved in a closed system?
In a closed system, the total momentum before and after an event remains the same. This is known as the law of conservation of momentum.
