1. PF Contest - Win "Conquering the Physics GRE" book! Click Here to Enter
Momentum homework problem
  1. Apr 30, 2006 #1
    :yuck: I have this problem that I'm not sure I am on the right track. The problem is A .20 kg billiard ball traveling at a speed of 15m/s strikes the side rail of the pool table at an angle of 60 degrees. If the ball rebounds at the same speed and angle, what is the cahnge in its momentum.
    I have the following formulas:
    ∆p=p2-p1 = ∆px + ∆py
    ∆px = p2x-p1x 2pcos θ
    ∆py = p2y – p1y = p2sin θ – p1 sin θ = 0
    So, if I calculate p = mv I get .3kg*m/s
    Do I plug that value in for p in the equations above, and then I'm not sure what to do with the ∆py equation.
  3. Apr 30, 2006 #2
    Staff Emeritus
    I'm not sure what you doing with this bit;
    Also, p = mv [itex]\neq[/itex]0.3.
    I suggest writing down the intial and final momentums taking note of their direction.
  4. Apr 30, 2006 #3
    Notice that the vertical component of the momentum is the same since the speed of the ball after the collision is the same and the angle is the same. Therefore, the only change is in the horizontal component ( lets call it the x component ). What happens to the horizontl component of the momentum? The horizontal component of the velocity is reversed right? It has to be brought to zero first, and then back to its initial speed in the opposite direction. So the magnitude of the change in velocity is 2v. Therefore the change in momentum is
  5. Apr 30, 2006 #4
    Problem worked
    Here is the full description and how I worked the problem
  6. Apr 30, 2006 #5
    the final answere
    I forgot to include the final answere
    then I have
    ∆p = ∆px - ∆py = -5.714 kg*m/s – 2.08 kg*m/s = -7.794 kg*m/s
  7. May 1, 2006 #6
    Staff Emeritus
    As dx said before, there is no change in the x component (the diagram changed things slightly) of the momentum. This equation; ∆p = ∆px - ∆py is just plain wrong. I suggest you start by writing it down like this;
    Inital momentum;
    pxi = ...
    pyi = ...
    Final momentum;
    pxf = ...
    pyf = ...
    Resolve you momentums into x and y components before you begin. For continuity make any motion in the left to right plane x, and in the bottom to top plane y.
