Momentum of a boat problem
A child in a boat throws a 6.40kg package out horizontally with a speed of 10.0 m/s. Calculate the veolcity of the boat immediately after, assuming it was initially at rest. The mass of the child is 26.0kg and that of the boat is 45.0kg. Ignore water resistance.
(m1+m2+m3)v(boat final) = m1v1(initial) + m2v2(initial) + m3v3(initial)
(6.40+26+45)v(boat final) = 6.4(10)+26(0)+45(0)
(77.4)v(boat final)=64
Dont seem right to me. Thanks in advance!
v(boat final)= 0.83 m/s
i know that we're suppose to treat it like an explosion problem. but im stuck there cuz the answer dont seem to make sense to me.
Answers and Replies
Let
m1 = mass of package
m2 = mass of boat+child
Initial momentum = Final momentum
Initial momentum = 0 = m1v1 = m2v2
Don't take my word for it though, i'm still very new to conservation laws myself...
the answer is the same...but what's the initial velocity of the package? is it 10m/s then? or is that the final velocity?
Velocity of the package is, as given, 10m/s. It will be part of final momentum.
Initial momentum = momentum when the system (boat+boy+package) is at rest
Final momentum = momentum at the moment of throwing of package
Do you know what the correct answer is?
no i dont.. that's the thing.
Reading the question it sounds like everything is at rest initially. What does this imply about the system initially? (See Siddhartmishra's post)
Post action we have a package travelling at 10m/s, and the boat travelling at some other speed to be determined. Recall that speed cannot determine direction per se, but it can determine backwords and forwards by a negative sign, thus we don't have to worry about vectors here. If the speed of the gift is 10m/s, what does this imply about the speed of the boat?
By answering that you'll be able to setup your equation properly and the answer should be acceptable.
Read my post #4 and solve accordingly by equating initial and final momentum... there is nothing wrong with the answer, it seems pretty plausible.
ok...so this is what i got.. i hope im right!
(6.40*0)+(26*0)+(45*0)=(6.4+26+45)v(boat final)
the answer is 0.
well...
you have got that toooooo wrong:rofl: :rofl: :rofl: :rofl: :rofl: :rofl:
the boat and chils are a system having same velocity while the package will have some other velocity
so...
initial momentum=0=finalmomentum = 6.4 X 10 + (boat + chiild) X V
-6.4X10=(boat+child)XV
'-' indicates boat travels in opposite direction to the package
hage567
1,509
the answer is 0.
But the package isn't on the boat anymore, so you must treat it separately from the boat+child! It goes off at 10 m/s, right?
You're initial momentum is correct, you need to work on the final now.
skittlez411,
Your first equation is wrong.
You should (always) start with the full equation, here:
m1v1(final) + m2v2(final) + m3v3(final) = m1v1(initial) + m2v2(initial) + m3v3(initial)
(assuming for example: 1=boat, 2=children, 3=package)
and replace carefully each term with the available information.
In particular you have:
v1(initial) = v2(initial) = v3(initial) = 0
v3(final) = 10 m/s
v1(final) = v2(final)
Hope it helps,
Michel
thank you guys so much! i really appreciate your help!
Related Threads on Momentum of a boat problem
  • Last Post
  • Last Post
11K
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
