Momentum problem?
  • Thread starter fightboy
A large, uniform-density cube of styrofoam has a side length of 3.0 m and a mass of 90 kg. It is at
rest on a horizontal, frictionless (ice) surface. An ice-skater with a mass of 60 kg is standing at rest,
touching one face of the cube. You should consider all of the ice-skater's mass to be located exactly at
the position of the cube's side. The ice-skater now pushes off against the cube. When the cube has
moved 4.0 m from its starting position, how far has the ice-skater moved?
mvi=mvf,
hard to tell what other equations come into play[/B]
tried to use conservation of momentum equation (mvi=mvf) to solve, but ended up falling short since I can't determine the velocities of the cube and the ice-skater. I know information about the side length of the cube and the ice skater's position on the cube will be important in figuring out the problem, but i just can't see how they are connected.
Answers and Replies
Simon Bridge
17,858
1,654
The conservation of momentum equation will give you one equation with two unknowns - you need to find another equation (or two) in those unknowns.
You have yet to use the distances - what is the relationship between the distance travelled and the velocity?
Note: you can also do this in terms of ratios - what is the skaters speed as a fraction of the cube's?
What does that suggest about the distances they travel in the same time?
CWatters
2,296
I tried to use conservation of momentum equation (mvi=mvf) to solve, but ended up falling short since I can't determine the velocities of the cube and the ice-skater.
What Simon said.
Write your equations.
Substitute Velocity = distance/time
You might find that the time cancels :-)
Related Threads on Momentum problem?
34K
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
