Momentum Problem: Find Speed of Block After Inelastic Collision
  • Thread starter dsptl
  • Tags
    Momentum
In summary, the problem requires finding the speed of block A after it collides inelastically with block B, which is initially at rest. The initial kinetic energy of block A equals its final potential energy, but the calculation does not take into account the effect of the collision.
dsptl
64
* Block A of mass 5kg is released from the rest at height of 5m. Then it hits 10kg block B, which at ground level. The collision in inelastic. Find the speed of the block after the collision if the block B was intially at rest.
Attempt:
Ki+Ui=Kf+Uf, since the block was at rest, Ki=0, and it goes to ground level so, Uf=0, thus Ui=Kf.
mghi=1/2mvf2, 5*9.8*5=1/2(5)vf2, vf=9.9m/s
but the answer is wrong...please help someone
Hi dsptl,
Attempt:
You've found the speed of block A right before the collision (assuming it slid freely down to ground level), but how do you take into account the effect of the collision itself? (By the way, since you mentioned that the collision was elastic, did you mean it was completely inelastic?)
Hi there,
I can see that you have attempted to use the conservation of energy equation to solve this problem. However, since this is an inelastic collision, some of the kinetic energy will be lost in the form of heat, sound, and deformation. This means that the final kinetic energy will not be equal to the initial potential energy.
Instead, we can use the conservation of momentum equation to solve this problem. In an inelastic collision, the total momentum before the collision will be equal to the total momentum after the collision. So, we can set up the following equation:
m1v1 + m2v2 = (m1 + m2)vf
Where m1 and v1 are the mass and velocity of block A before the collision, m2 and v2 are the mass and velocity of block B before the collision, and vf is the final velocity of the combined blocks after the collision.
We know that block A is initially at rest, so v1 = 0. We also know that block B is initially at rest, so v2 = 0. Substituting these values into the equation, we get:
0 + 0 = (5+10)vf
Solving for vf, we get:
vf = 0 m/s
This means that the two blocks will stick together and have a final velocity of 0 m/s after the collision.
I hope this helps! Keep up the good work in your scientific problem-solving.
1. What is momentum and how is it related to collisions?
Momentum is a measure of an object's motion, and is calculated by multiplying its mass by its velocity. In collisions, momentum is conserved, meaning that the total momentum of the objects before the collision is equal to the total momentum after the collision.
2. What is an inelastic collision?
An inelastic collision is a type of collision where kinetic energy is not conserved. This means that some of the initial kinetic energy is lost and converted into other forms of energy, such as heat or sound.
3. How do you find the speed of a block after an inelastic collision?
To find the speed of a block after an inelastic collision, you can use the equation m1v1 + m2v2 = (m1 + m2)v3, where m1 and v1 are the mass and velocity of the first object before the collision, m2 and v2 are the mass and velocity of the second object before the collision, and v3 is the final velocity of both objects after the collision.
4. What information do you need to solve a momentum problem involving an inelastic collision?
To solve a momentum problem involving an inelastic collision, you need to know the masses and velocities of the objects before the collision, as well as the coefficient of restitution, which is a measure of how much kinetic energy is lost in the collision.
5. How does the coefficient of restitution affect the final speed of the objects after an inelastic collision?
The coefficient of restitution, denoted as "e", is a number between 0 and 1 that represents the amount of kinetic energy lost in a collision. A higher value of e means that less kinetic energy is lost, resulting in a higher final speed for the objects after the collision. Conversely, a lower value of e means more kinetic energy is lost, resulting in a lower final speed.
