Momentum to stop a train
  • Thread starter Smartguy94
Smartguy94
41
Find the speed at which Superman (mass=89.0 kg) must fly into a train (mass = 17755 kg) traveling at 85.0 km/hr to stop it.
Running into the train at that speed would severely damage both train and passengers. Calculate the minimum time Superman must take to stop the train, if the passengers experience an average horizontal force of 0.410 their own weight
How far does the train then travel while being slowed to a stop?
p=mv
F=dp/dt
F=ma
J= p2-p1
J=F(t2-t1)
I found the speed at which superman should fly by
m1v1=m2v2
17755*85.0=89.0*v2
v2=1.70×10^4 km/hr
for the minimum time this is what I do, but I got it wrong
since J=F(t2-t1)
and J=p(final)-p(initial)
then J=mv-mv
J=(89)(0)-(89)(1.70×10^4)
J=1513000
J=F(t2-t1)
1513000=(.41)(t)
t=3.68x10^6hr
then for the distance I couldn't calculate it because I had no idea what the time is
Answers and Replies
Simon Bridge
17,874
1,657
Superman has to do work on the train to slow it to a stop - this work is the change in kinetic energy of the train and work is force (given) times distance.
You could treat it as a kinematics problem, assuming constant acceleration. The v-t graph is a triangle height vtrain and base T (= time to stop), the slope of the graph is the acceleration: a = -F/mtrain = vtrain/T but conservation of energy is the way to go here.
gneill
Mentor
20,945
2,886
To calculate the time required to bring the train to a halt you've chosen to use the change in momentum, Δp = F*Δt = M*Δv (You called Δp "J"). Then
[tex] \Delta t = \frac{M \Delta v}{F} [/tex]The problem is, you need to know what F is. You're given the hint that the maximum horizontal force on a given passenger should be 0.410 times their weight. Well, if their weight is m*g then F = 0.410*m*g, and the maximum acceleration would be F/m = 0.410*g. Apply this acceleration to the train as a whole and you get:
[tex] F = 0.410 M g [/tex]
You'll have to be careful with the units here! You've been working with km and hours, and g is usually specified in m and seconds.
Suggested for: Momentum to stop a train
  • Last Post
  • Last Post
  • Last Post
