Monoprotic weak acid in water
In summary, the question is asking for the equilibrium constant, Ka, for the reaction of a monoprotic acid dissolved in water to produce a 0.0153 M solution with a pH of 6.31. The student has attempted to solve the problem using ICE tables, but has received feedback about accounting for the initial H+ concentration from water. The solution requires a systematic approach and the use of equations such as Ka, Kw, mass balances, and charge balance. The student is advised to focus on understanding fundamental concepts rather than relying on tables.
yango_17
60
If enough of a monoprotic acid is dissolved in water to produce a 0.0153 M solution with a pH of 6.31, what is the equilibrium constant, Ka, for the reaction?
I have attempted to solve this problem using ICE tables, but keep getting the incorrect answer. One feedback stated that I needed to account for the initial H+ concentration due to water, which is 10^-7 M, but I'm not sure how to go about putting this into the ICE table. Thanks in advance for any help
Please show your work and the result you got, hard to comment on the problem not seeing what you did.
In general concentration of H+ from the water autodissociation is not 10-7 M, as its concentration changes when the acid dissociates shifting the water dissociation equilibrium. This can be still solved, but not with just an ICE table. You would need a full, systematc approach, which requires writing all equations describing the system (Ka, Kw, mass balances, charge balance) and solving for Ka.
Instead of tables which IMHO will leave you with no knowledge or ability a year after the last time you've used them, I would use the simple fundamentals which you will be able to call on any time needed.
What are the relevant equations for this question?
1. What is a monoprotic weak acid?
A monoprotic weak acid is a type of acid that can donate only one hydrogen ion (H+) to a solution. It is considered weak because it does not completely dissociate in water, meaning only a small percentage of the acid molecules actually release hydrogen ions.
2. How does a monoprotic weak acid behave in water?
When a monoprotic weak acid is added to water, it dissociates into its conjugate base and a hydronium ion (H3O+). However, because it is a weak acid, the dissociation is incomplete, resulting in a mixture of undissociated acid molecules and dissociated ions in the solution.
3. What is the pH of a solution containing a monoprotic weak acid?
The pH of a solution containing a monoprotic weak acid depends on the concentration of the acid, as well as its dissociation constant (Ka). As a general rule, the more concentrated the acid is, the lower the pH will be. Additionally, a higher Ka value indicates a stronger acid, resulting in a lower pH.
4. How does the strength of a monoprotic weak acid affect its pH?
The strength of a monoprotic weak acid is measured by its dissociation constant (Ka). A higher Ka value indicates a stronger acid, which means that the acid will dissociate more in water and result in a lower pH. A lower Ka value, on the other hand, indicates a weaker acid and a higher pH.
5. What factors can affect the dissociation of a monoprotic weak acid in water?
The dissociation of a monoprotic weak acid can be affected by several factors, including concentration, temperature, and the presence of other substances in the solution. A higher concentration of the acid or an increase in temperature can promote dissociation and result in a lower pH. Additionally, the presence of a strong acid or base in the solution can also affect the dissociation of a weak acid.
