• Support PF! Buy your school textbooks, materials and every day products via PF Here!
Monte Carlo Integration
$$f(x)=NormalPDF(x,2,1)+NormalPDF(x,2,(1/2)^2)$$.
where NormalPDF(a,b) is the PDF for a normal distribution with mean a and variance b.
Use Monte Carlo Integratoion to find: $$\int_{-10}^{10}f(x)dx$$
2. Relevant equations
The solution to this integration is 2.
I use the method described in this video:
3. The attempt at a solution
What I have done is as follows:
- draw n (=5000) random numbers uniformly distributed from -10 to 10. in R: runif(n,-10,10)
- evaluate the function f for each of the n randomly distributed numbers so I end up with n different values of f
- find the mean of those values and that is my integral.
I end up with 0.1 instead of 2. What do I do wrong? When I experiment with $$\int_{0}^{1}\exp(-x^2/2)$$ and use the same method I get the correct result
When I multiply by 20 then I get the correct answer. I assume it has something to do with my integration Interval. But I can't see why it gets me the correct answer when mulitiplying by 20
andrewkirk
Insights Author
1,357
By generating a large number of random numbers ##x## in the integration interval [-10,10] and taking the average of ##f(x)## you have estimated the mean of ##f(x)## in the interval. The mean of a function ##f## over an interval ##[a,b]## is defined as
$$\frac{\int_a^b f(x)dx}{b-a}$$
So, to estimate the integral, you need to multiply your estimate of the mean (0.1) by ##(b-a)## which in this case is ## (10--10)=20##.
Want to reply to this thread?
"Monte Carlo Integration" You must log in or register to reply here.
Physics Forums Values
We Value Quality
• Topics based on mainstream science
• Proper English grammar and spelling
We Value Civility
• Positive and compassionate attitudes
• Patience while debating
We Value Productivity
• Disciplined to remain on-topic
• Recognition of own weaknesses
• Solo and co-op problem solving
