Momentum Question: Cannon on Slope with Friction | Minimal Velocity to Stop
  • Thread starter devanlevin
In summary, the minimal velocity of the shell that will cause the cannon to stop after passing a distance of L on an incline of θ with a friction coefficient of μ is found by finding the impulse exerted on the cannon perpendicular to the incline and relating it to the change in momentum parallel to the incline due to increased friction. The resultant change in momentum is then used to find the minimum shooting velocity, taking into consideration the impulse exerted on the cannon.
devanlevin
a cannon with a mass of M is let free from the top of a slope with an incline of [tex]\vartheta[/tex] the friction between the cannon and the slope is given as [tex]\mu[/tex]N.
after the cannon has passed a dstance of L it shoots a shell, with a mass of m horizontally, what is the minimal velocity of the shell so that the cannon will stop,?
im not sure if this means that M is the mass of the cannon and the shell, or of the cannon alone, but form the answer i think that they mean that it is just the mass of the cannon, and somehow they don't take the mass of the shell into consideration until its shot.
the answer is
Umin=(M+m)/m(cos[tex]\vartheta[/tex]-[tex]\mu[/tex]sin[tex]\vartheta[/tex])*[tex]\sqrt{2Lg(sin[tex]\vartheta[/tex]-[tex]\mu[/tex]cos[tex]\vartheta[/tex])}[/tex]
what i did was,
I)drew a diagram,-- http://picasaweb.google.com/devanlevin/DropBox?authkey=sbH95pBl_D8#5278474258602595442
II)found the cannons acceleration
III)found its velocity after it had passed L
IV)found the minimal Velocity of th shell
II)to find the acceleration
using[tex]\sum[/tex]F=ma=mgsin[tex]\vartheta[/tex]-[tex]\mu[/tex]N
acceleration downhill a=g(sin[tex]\vartheta[/tex]-[tex]\mu[/tex]cos[tex]\vartheta[/tex])
III)to find the cannons velocity
V^2=2a[tex]\Delta[/tex]x
velocity downhill V=[tex]\sqrt{2Lg(sin[tex]\vartheta[/tex]-[tex]\mu[/tex]cos[tex]\vartheta[/tex])}[/tex]
IV) to find the minimum shooting velocity
(M+m)V=mu*cos[tex]\vartheta[/tex]+MU (when MU=0)
u=V(M+m)/mcos[tex]\vartheta[/tex]
which would be my final answer except that the answer according to the book is
u=V(M+m)/m(cos[tex]\vartheta[/tex]-[tex]\mu[/tex]sin[tex]\vartheta[/tex])
where does this extra bit come from? where have i gone wrong?
Realize that during the explosion of the cannon, an impulse is exerted perpendicular to the incline as well as parallel to it. That increases the normal force, and thus friction, resulting in a change in momentum parallel to the incline. (Momentum is not conserved.)
so how do i approach that? if momentum is not conserved, what do i know? up till step (IV) have i done it all right?
what should my next steps be
Everything is fine up to there. Consider the impulse on the cannon perpendicular to the incline. (What's the cannonball's momentum in that direction?) Relate that to the change in momentum parallel to the incline due to the increased friction during the explosion.
would that would be mu*sin[tex]\vartheta[/tex]??
now what do i say? is the total momentum ==> (M+m)V=mu - mu*sin[tex]\vartheta[/tex]??
is that what you are saying the loss of momentum is the cannonball's momentum in that direction?
how do i relate this to the friction?
Right.
Not quite, you have to figure out resultant change in momentum parallel to the incline.
And that's where friction comes in.
Consider: FΔt = mu sinθ
But here, F is the normal force. What additional friction force does that correspond to? Find the impulse parallel to the incline due to the increased friction force.
how do i figure out resultant change in momentum parallel to the incline. what do i know to work this out?
i know that the momentum before was Mv parallel to the incline, and 0 perpendicular to the incline, and after that, was the total momentum [mu*sin[tex]\vartheta[/tex] + mu*cos[tex]\vartheta[/tex]]?? just a guess:(
then what else do i know, - the F on y-axis is N, which i need to find out, and the force on x-axis is f and mgsin[tex]\vartheta[/tex], now i see that
Py=[tex]\int[/tex](N)dt
Px=[tex]\int[/tex](Mg-f)dt=[tex]\int[/tex](Mg)dt-[tex]\mu[/tex][tex]\int[/tex](N)dt
Px=Mg(dt)-[tex]\mu[/tex]Py
then can i ignore the mg force assuming it does not affect the momentum that much
Px=-[tex]\mu[/tex]Py
is this correct, still not sure what to do with it, problem being that momentum isn't conserved,
feel like I am just writing things and running with them not really knowing what to do next
Find the impulse due to the increased friction. Reread my last post, near the end. How does friction relate to normal force?
im not managing to connect the impulses to an actual force, i understand everything you are saying, but can't put it into equations,
i know that FΔt = mu sinθ, and that the force on the y-axis is the normal force,
i know that the force on the x-axis is the friction which is controlled by the normal force, therefore, the impulse on the x-axis is [tex]\mu[/tex]*the impusle on the y axis. but i don't know how to get anywhere from this information.
could you please show me your workings and your steps? has this has turned out to be a lot more complicated than i though, or am i just missing something?
That's really all there is to it, you just have to recognize what you have.
The impulse along the x-axis is then -μmu sinθ (negative, since it acts in the direction of friction). And impulse is the change in momentum, so (in the x direction):
Initial momentum + impulse = final momentum
initial momentum + impulse = final momentum of cannon (0) + final momentum cannonball
Give it another shot.
Moomentum sounds like a property of a mooving cow.
getting there...
can i say ..
(M+m)V=mu + the impulse
and that the impulse is
x -μmu sinθ
y -mu sinθ
is this right??
from here i can find the magnitude of the impulse, and from the equation find u, although looking at this doesn't look like ill come to the right answer
(M+m)V-μmu*sinθ=mu
(M+m)V=mu+μmu*sinθ
(M+m)V=mu(1+μ*sinθ)
from this i get
u=[(M+m)/m]*V/(1+μ*sinθ)
but correct the answer is
u=[(M+m)/m]*V/(cosθ-μ*sinθ)
dont worry about it, i got it,, I am such an idiot,,, see where I've gone wrong,, thanks for the help.
1. What is momentum?
Momentum is a physical quantity that describes the motion of an object. It is the product of an object's mass and velocity.
2. How is momentum calculated?
Momentum is calculated by multiplying an object's mass (m) by its velocity (v): p = m x v. The unit of momentum is kg*m/s.
3. What is a cannon on a slope with friction?
A cannon on a slope with friction is a physical scenario where a cannon is placed on a slope and experiences the force of friction as it moves down the slope.
4. How does friction affect the momentum of the cannon?
Friction is a force that opposes motion and causes objects to slow down. In the case of the cannon on a slope, friction will decrease the momentum of the cannon and eventually bring it to a stop.
5. What is the minimal velocity needed to stop the cannon on the slope?
The minimal velocity needed to stop the cannon on the slope will depend on the mass of the cannon, the angle of the slope, and the coefficient of friction between the cannon and the slope. This can be calculated using the equations of motion and the concept of work and energy.
