More Help With Lagrangian Mechanics
  • Thread starter cmmcnamara
cmmcnamara
122
So in my internet readings on Lagrangian mechanics I started researching applications with non-potential and/or non-conservative forces and came across this page:
http://farside.ph.utexas.edu/teaching/336k/Newton/node90.html
This page is fascinating but I'm having a bit of difficulty understanding a piece of the first example. Can some one explain to me the constraint function they came up with? Its labeled as equation 727. I feel like I'm missing something obvious but I just can't figure it out. Thank you!
Answers and Replies
Studiot
5,441
Isn't this the no slip condition?
That is in words
The distance (χ) down the plane = the angle turned through by the cylinder times the radius
vanhees71
Insights Author
2021 Award
20,858
11,694
Precisely: If the cylinder is rolling without slipping the distance, travelled of a fixed point from the initial time, where we set [itex]\phi=0[/itex] is given by the circumference along the cylinder boundary, i.e., it's [itex]a \phi[/itex], where [itex]a[/itex] is the cylinder's radius. The same distance the cylinder's center axis has travelled, i.e., we must have the constraint
[tex]x=a \phi,[/tex]
where we have chosen [itex]x=0[/itex] as an initial condition. The constraint function is then given (up to a sign and an overall multiplicative constant, which both are irrelevant for the solution of the problem) thus reads in this case as given by Eq. (727).
All the scripts of Fitzpatrick's are just mavelous by the way!:smile:
cmmcnamara
122
Sigh.....I knew it was something obvious, thanks a lot guys!
Suggested for: More Help With Lagrangian Mechanics
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
