More ladder operators
  • Thread starter jostpuur
Main Question or Discussion Point
Is there a simple expression for the ladder operators, in terms of x and [itex]-i\hbar\partial_x[/itex], for the infinite potential well? After some attempts, I couldn't figure out any nice operators that would map functions like this
[tex]
\sin\frac{\pi n x}{L} \mapsto \sin\frac{\pi(n\pm 1)x}{L}.
[/tex]
Answers and Replies
Hurkyl
Staff Emeritus
[tex]
[/tex]
What's wrong with just using this to define a pair of operators? Such sinusoids form a basis for the state space, don't they? Is expressing it in terms of those operators a necessity?
If you really need to write things in terms of those operators, it seems straightforward by using the angle addition formulas for trigonometric functions. You'll probably have to use operators like [itex]\sin X[/itex] and [itex]\cos X[/itex], though.
I'm not sure.
Yes.
I'm not sure.
Better to know, than to not know! If some nice form for the operators exists, I have no intention to ignore it.
It didn't seem straightforward when I tried it.
[tex]
\exp\frac{i\pi n x}{L}\; -\; \exp\frac{-i\pi nx}{L} \quad\mapsto\quad
\exp\frac{i\pi n x}{L}\exp\frac{i\pi x}{L} \;-\; \exp\frac{-i\pi nx}{L}\exp\frac{-i\pi x}{L}
[/tex]
Multiplying by some function doesn't do this. There is always some problems with cross terms. Derivatives seem problematic, because they bring [itex]\propto n[/itex] factors down from the exponents.
Hurkyl
Staff Emeritus
Incidentally, does [itex]\partial_x[/itex] even count as an operator here? When applied to a state, it usually produces something that isn't a state!
Well, by far the nicest form of these operators is given by the expression you wrote! Let [itex]\psi_n[/itex] denote those wavefunctions, and write everything in that basis. Then, the raising operator is simply given by
[tex]A \psi_n := \psi_{n+1}[/tex]
2,099
It seems natural to work in the space spanned by
[tex]
\exp\frac{i\pi kx}{L},\quad k\in\mathbb{Z}
[/tex]
and consider the physical state space as a subspace. It is allowable to go outside temporarily.
I didn't take a closer look at the infinite matrices yet. It could be I'm returning to this later or soon.
hmhmh.... or is it allowable? :biggrin: I'm not sure really... The insistence on writing everything in terms of x and p is getting strange of course...
Hurkyl
Staff Emeritus
I want to say that you can write the "Number" operator as
[tex]N = \sqrt{ \partial_x^2 }[/tex]
where the square root one is the one induced by the real number square root. (And this would solve your problems with n appearing) Unfortunately, the reasonability of this expression is on the boundary between my knowledge and my optimism. :frown:
reilly
The sines are complete, in configuration space. Further they are eigenstates of the free Hamiltonian. When in doubt, brute force is sometime a good way to go. Lets call one of these eigenstates | S,n> so that <x|S, n> =sin (n pi x/L). Your ladder operator for going up then becomes
Sum over n{|S,n+1><S,n|} -- i've neglected constants
A similar expression holds for the n-> n-1 operator, which is adjoint to the above operator..
You also might be able to do this by converting to an oscillator basis; there's a standard generating function for Hermite polynomials that might do the trick.
Regards,
Reilly Atkinson
reilly
Hurykyl's Number Operator
Your operator shows up, for example, in classical E&M. The standard approach is to go to a Fourier representation, and end up with deleta functions and principle parts. Discussed in Mandel and Wolf, Optical Coherence ...., page 223.
Regards,
Reilly Atkinson
Related Threads for: More ladder operators
  • Last Post
  • Last Post
  • Last Post
  • Last Post
11K
  • Last Post
  • Last Post
  • Last Post
  • Last Post
