Light Relativity Questions - Explained
  • Thread starter SigurRos
  • Tags
    Light
In summary: Earth...then the relative speed of everything around you will be greater than the speed of light. For example, if you're traveling away from an observer on a moving train, the train will be traveling away from you faster than the speed of light, and the observer on the train will see the light from the flashlight moving towards them at a slower speed than the speed of light. But if you're on the train, and the observer on Earth is stationary and looking at you, then the light from the flashlight will appear to move towards you at the speed of light.
SigurRos
25
Hey, I was reading through a few of these posts, and something crossed my mind:
Say there was a spaceship traveling away from Earth at the speed of light. To observers on earth, the ship would travel at c, and to observers on the ship, Earth would be traveling at c. Suppose that the ship sent a beam of light back to earth. To observers on the ship, the light would travel towards Earth at c, but since Earth was moving away at c, wouldn't the light never reach earth? Similarly, since the ship is moving away from Earth at c, and the light is moving toward Earth at c, wouldn't the beam of light have to appear to be unmoving, since if it was moving away from the ship at c (or at any speed), the relative speed of the beam with respect to the ship would be c + c(or any other positive velocity), and this would violate relativity?
I confused myself with these thoughts, so I was wondering if anyone could explain it to me.
Thanks
Thanks
Relativity says it's impossible for a massive object like a spaceship to travel at exactly the speed of light, although it can get arbitrarily close from our perspective. Particles moving at c do not have their own inertial rest frames--the Lorentz transformation equations for translating between different frames' coordinate systems give infinities if you try to plug in v=c.
OK then, suppose the ship was extremely close to the speed of light, say .999999*c. would the light have to move away from the ship at .000001*c?
No, the light would still move at speed c, from the point of view of an observer on the earth, or any other observer, for that matter.
Nope, the ship would measure the light to be traveling at c relative to itself. It may help to remember that each observer calculates speed in terms of distance/time as measured on their own set of rulers and clocks, and of course each observer sees the other's rulers shrunk and the other's clocks slowed down, and if each observer has a set of clocks at different locations which are synchronized in his own frame, other observers will see these clocks as out-of-sync (different reference frames disagree about 'simultaneity', so two events that happen at the same time-coordinate in one frame can happen at different time-coordinates in another). Because of this, velocity addition doesn't work the same way in relativity that it does in classical mechanics--in classical mechanics, if I see a car driving by my at u=30 mph, and he sees a car driving by him in the same direction at v=20 mph, then to figure out how fast the second car is driving relative to me, I'd just use the formula u + v = 50 mph. But in relativity, the correct formula would instead by [tex](u + v)/(1 + uv/c^2)[/tex] -- see this page for more on this. So, suppose I observe a ship moving away from me at 0.9c, and an observer on the ship sees a light beam moving in the same direction at velocity c relative to him, and I want to know how fast the beam is moving relative to me--in this case I'd set u=0.9c, v=c, and conclude that the velocity of the beam relative to me is (1.9c)/(1 + 0.9) = c.
The wouldn't this violate relativity, since the ship and the beam of light would appear to be moving away from each other at a speed greater than c?
If you're traveling away from Earth... and you shine the light back at earth, and not in FRONT of the direction you are traveling... then i see no problem here.
[Quote SigurRos]Then wouldn't this violate relativity, since the ship and the beam of light would appear to be moving away from each other at a speed greater than c?
No this wouldn't violate anything... no object is moving faster than the speed of light here... Even if you're both traveling away from each other at .99c, then you're moving away from each other at 1.98c, still though, neither of you are traveling faster than c from an outsiders reference frame perspective... regardless of what it looks like from your reference frame... The objects are still not traveling at faster than c... you see what i mean? to violate relativity an individual object must actually travel at faster than c.. that's not being done.
My calculation was assuming the ship and the light beam were moving in the same direction, but if they were instead moving in opposite directions, then in my frame the distance between them could indeed be increasing at a rate faster that 1 light year per year. But relativity only says that no individual object can move faster than c in any given frame, not that the distance between two objects can't increase faster than c in a given frame. And despite the fact that I see the distance between the ship and the light beam increasing faster than c, in the ship's own rest frame the light beam is only moving away from it at c.
I think we might be losing sight of the fact that velocities in excess of C are impossible from the perspective of the OBSERVER. Sure, you can see two photons going in opposite directions, each moving at c - giving you a "calculated" relative velocity between them of 2c (from your point of view). However, from the perspective (= inertial frame of reference) of each of the photons, the other is traveling at c.
Going back to your original question, and assuming that a spaceship CAN travel at the speed of light (which it could if it had zero mass!), then, yes, the spaceship pilot would see that the light beam would never reach Earth, whereas Earthlings would see that the light beam WOULD reach Earth after a time interval of of D/c, where D is the distance (as measured from Earth) between the Earth & the spaceship when the latter sent back the beam of light. There is no paradox here, because observers on the spaceship would see that time on Earth was standing still (time dilation), so they would never see Earth time advance to the instant when (according to observers on Earth) the light beam reached it. It all boils down to the relativistic effect that is at the bottom of all of its predictions: simultaneity is relative.
Put another way, two observers will never measure their speed between them to be greater than C. If one moves away from the Earth at .99c and another moves away in the other direction at .99c, they cannot just add their speeds together and come up with 1.998c as the relative speed of the other. They must add them using the equation for relativistic velocity, otherwise the speeds won't match what they measure by bouncing a laser off each other.
As I said in my first post on this thread, photons don't have their own reference frame--the lorentz transformation doesn't work for v=c, and anyway giving photons their own inertial frame would violate the basic postulate that the laws of physics should look the same in all inertial frames (because the laws of electromagnetism don't allow electromagnetic waves to be at rest). So, there is no answer to the question about what speed photons have from the perspective of another photon.
1. What is the theory of relativity?
The theory of relativity, developed by Albert Einstein, is a theory of space and time that explains how objects move in the universe. It consists of two main theories: the special theory of relativity and the general theory of relativity. The special theory of relativity describes the relationship between space and time for objects moving at constant speeds, while the general theory of relativity describes the effects of gravity on space and time.
2. How does the theory of relativity explain the speed of light?
The theory of relativity states that the speed of light is constant and the same for all observers, regardless of their relative motion. This means that the speed of light is a fundamental constant in the universe and cannot be exceeded. This is in contrast to classical physics, which believed that the speed of light was relative to the observer's frame of reference.
3. What is the concept of time dilation in relativity?
According to the theory of relativity, time is not absolute and can vary depending on the relative motion of objects. This means that time can appear to pass at different rates for different observers. This effect is known as time dilation and has been proven through experiments with high-speed particles and atomic clocks.
4. Can the theory of relativity be proven?
The theory of relativity has been extensively tested and verified through numerous experiments and observations. For example, the bending of starlight by the sun, the slowing of time for high-speed particles, and the accuracy of GPS systems all provide evidence for the theory. However, like all scientific theories, it is always subject to further testing and refinement.
5. How does the theory of relativity impact our understanding of the universe?
The theory of relativity has had a profound impact on our understanding of the universe. It has revolutionized our understanding of space, time, and gravity, and has provided a framework for modern physics. It has also led to new technologies and advancements in fields such as astronomy and cosmology. The theory of relativity continues to be a cornerstone of modern physics and is essential for understanding the workings of the universe.
