Homework Help: More magnetic fields
  1. Nov 21, 2005 #1
    a long wire is bent into a hairpin as showqn in the figure. If the wire carries a curent of i = 1.5A
    a) what is the magnitude and the direction of B as point a?
    b) at point b very far from a?
    assume R = 5.2mm
    a) for a
    since R is constant s = 2 pi R
    [tex] B = \frac{\mu_{0} i}{2R} [/tex] and this field points straight out of the page.
    b) for b the magnetic field is zero because the circular part has no effect on B. Also you have two wires carrying opposiute currents, thus creating equal and opposing fields thus the magnetic field is zero at B.
  3. Nov 22, 2005 #2
    mezarashi
    For part (a), I'm afraid the question may be a little more complicated. You will be looking at the Biot-Savart law.
    In part (b), use the right hand rule. Do the fields cancel? If the current i is fluctuating, the magnetic field will fluctuate as well. Fluctuating magnetic fields introduce EMF. Why do you think wire pairs are usually twisted, and called twisted pairs as in CAT5 ethernet cables?
  4. Nov 22, 2005 #3
    ok for the first part if im using biot savart
    [tex] B =\frac{\mu_{0} i}{4 \pi} \int \frac{ds \cross r}{r^3} [/tex] then what is ds?
    here ds seems to be infinitely long and the angle between ds and r varies from 180 to 90 and then from 90 to 180
    then how would one find the relation between ds and theta?
  5. Nov 22, 2005 #4
    also i is constant in the second part so there would be no emf created
    we havent gotten to that part of the chapter yet so im thinking that would not be a factor here
    ok due to the top part of the wire the field points upward
    for the bottom part upward as well
    so the field would be [tex] B = \frac{\mu_{0} i}{\pi R} [/tex] ?
  6. Nov 22, 2005 #5
    mezarashi
    ds is your constant of integration of course. It is a differential element of your wire.
    The correct form of the law is in fact.
    [tex] B = \frac{\mu_o I}{4\pi}\int \frac{dl \times \vec{r}}{r^3}[/tex]
    If we want to solve without the use of vector calculus, we can simplify by deciding on the direction and working only with magnitudes. We can see that if the current and vector r is on the x-y plane, then the magnetic field must always be in the z or k direction. We can then write
    [tex] B = \frac{\mu_o I}{4\pi}\int \frac{dl sin\theta}{r^2}[/tex]
  7. Nov 22, 2005 #6
    mezarashi
    My example earlier was merely to show that the B field is indeed not zero. It is very real and also a problem in telecommunication systems.
    Yes, if you assume the infinite wire approximation where Ampere's law holds.
  8. Nov 22, 2005 #7
    ok i get this so far
    but isnt dl infinite? also doesnt theta vary?
  9. Nov 22, 2005 #8
    mezarashi
    You need to apply your calculus. You cannot integrate unless your variable of integration is the same of that of the other variables present in the function. You have two choices, convert [tex]sin\theta[/tex] into terms of length [tex] l [/tex] or perform a change variables [tex]dl \longrightarrow d\theta[/tex]. You will find that doing the latter will lead to a much much easier integral.
  10. Nov 22, 2005 #9
    not sure how a change of variables would be used here...
    i will attempt to find theta in terms of l
    i use the attached diagram but perhaps i may not be doing this right
  11. Nov 22, 2005 #10
    mezarashi
    Change of variables starts by creating a relationship
    [tex] tan \theta = \frac{d}{-l}[/tex]
    [tex] l = - d cot \theta [/tex]
    [tex] dl = d csc^2 \theta d\theta [/tex]
    Then your integral reduces to
    [tex] B = \frac{\mu_o I}{4\pi}\int sin\theta d\theta[/tex]
  12. Nov 22, 2005 #11
    i see how thats done
    you got a -l becuase of your refernce system
    and theta varies from 180 to 90 and then 90 to 180 again
    then the magnetic field would be [tex] \frac{\mu_{0} i}{2 \pi} [/tex]
    forh te semi cicular part of the loop
    [tex] \frac{\mu_{0} i}{4R} [/tex]
    adding these two yields the magnetic field at a
  13. Nov 23, 2005 #12
    one thing...
    the magneticfield due to the top wire is integrated from theta = 180 to theta = 90
    for the bottom one it is integrated from 90 to 180
    when i subtract the two i get
    [tex] \frac{\mu_{0} i }{2 \pi} [/tex]
    for the semio circular part the field is [tex] \frac{\mu_{0} i}{4R} [/tex]
    so the field at a is [tex] \frac{\mu_{0} i }{2 \pi} + \frac{\mu_{0} i}{4R} [/tex]
    is this correct/
