More SHM problems
  • Thread starter bcjochim07
bcjochim07
374
#1 A spring with spring constant k is suspended vertically from a support and a mass m is attached. The mass is held at the point where the string is not streteched. Then the mass is released and begins to oscillate. The lowest point in the oscillation is 20 cm below the point where the mass was released. What is the oscillation frequency?
#2 A 300g oscillator has a speed of 95.4 cm/s when its displacement is 3 cm and a speed of 71.4 cm/s when its displacement is 6 cm. What is the oscillator's maximum speed.
#1 shouldn't be that difficult of a problem, but it's giving me trouble
Here's what I know: amplitude = .20 m
The total energy= 1/2k(.20 m)^2= 1/2m(vmax)^2
vmax= omega*A
But I can't figure out how to substitute the equations into each other to get the correct answer, which is 1.58 Hz
#2 I have also tried substituting the equations into each other:
3cm= Acos(omega*t+phi)
95.4 cm/s= -omega*A sin (omega*t+phi)
6 cm= Acos(omega*t + phi)
71.4 cm/s = -omega*A sin( omega*t + phi)
Any hints would be greatly appreciated. Thanks.
Answers and Replies
bcjochim07
374
any help would be appreciated
alphysicist
2,238
bcjoshim07,
problem #1. The amplitude in the first part is not 20cm. Be careful to think about how the mass was released.
problem #2. Try using energy conservation for the three points.
bcjochim07
374
i don't see how it wouldn't have an amplitude of 20 in #1 because it's released from equilibrium and isn't amplitude the maximum displacement from equilibrium?
bcjochim07
374
problem 2 I understand now. Thanks!
alphysicist
2,238
bcjochim07,
It was not released from equilibrium in this problem. Equilibrium is that point at which the spring is stretched enough so that the spring force is cancelling out the weight force. But this mass is released from the point where the spring is not stretched. What would that point be?
bcjochim07
374
where kx=mg but I'm still not sure where to go with it
bcjochim07
374
no wait that's not right
bcjochim07
374
hmmm... a point where the string is not stretched...I'm still not sure couldn't it be any point above where it would be if it were just hanging from the string?
alphysicist
2,238
So they release the mass from rest, and it goes downward a total of 20cm. How far up does it go after that?
How is the amplitude related to the total displacement that the mass undergoes while it is moving downwards from the highest to the lowest point?
bcjochim07
374
it is half of that amount so then the amplitude is 10cm? and then where should I go with that?
alphysicist
2,238
Write a force equation for the equilibrium point. (Where is the equilibrium point?) That will be an expression involving k and m. What do you get?
Then the normal formula for frequncy
[tex]
f=\frac{1}{2\pi} \sqrt{\frac{k}{m} }
[/tex]
bcjochim07
374
kx=mg
so k=mg/x but how do I know what the equilibrium point is?
bcjochim07
374
so equilibrium is at x=mg/k
alphysicist
2,238
Looks good; do you know what x is? Once you have that you're almost done.
bcjochim07
374
Ahhh... so the equilbrium point is at 10cm so k=mg/.1m
substituted that into the formula and get frequency= 1.58 Hz
I'm still a little unsure of how we defined our coordinates--we must have defined them as the lowest point being x=0
alphysicist
2,238
Well, we know the release point is at the positive amplitude, so I would call that x=+10 for purposes of the oscillation (using the sine or cosine function, etc.). (That's because the oscillation includes the effects of gravity.)
However, for purposes of calculating the total spring force, we would probably want to call x=0 that point at which the spring is unstretched. Because if it's not stretched it is not putting a force on the mass, so F=0.
Suggested for: More SHM problems
  • Last Post
  • Last Post
  • Last Post
