Trig Substitution: Solving for the Missing Identity
In summary, the conversation discusses solving a problem involving trig substitution and finding the correct identity to use. The solution involves integrating by parts and using the substitution u=tanx.
quickclick330
83
[SOLVED] More trig substitution help...
I've looked at this problem about 3 times and still can't figure it out...where identity did they use to substitute out the part in the red box? Thanks for the help
What's the step you don't understand?
[tex] \int \tan^{4}x \mathrm{d}x = \int \tan^{2}x \left(\sec^{2}x - 1\right) \mathrm{d}x [/tex]
or
[itex] \int \tan^{2}x \left(\sec^{2}x - 1\right) \mathrm{d}x = \int \tan^{2}x \sec^{2}x \mathrm{d}x - \int \tan^{2}x\mathrm{d}x[/itex].
[tex]\sec^2 x - 1 = \tan^2 x[/tex] and [tex]\tan^2 x \cdot \tan^2 x = \tan^4 x[/tex].
for me it's unclear how to integrate
[tex]\int\tan^2 x\sec^2 x dx=\int (\sec^2 x-1)\sec^2 x dx=\int \frac{1}{\cos^4}dx-\tan x[/tex]
So how to integrate
[tex]\int \sec^4 dx[/tex]
Integration by parts a few times does it, or write
[tex]\int \sec^2 x (\tan^2 x + 1) dx [/tex] and let u= tan x.
But rather than integrate sec^4, keep the original integral,
[tex]\int \tan^2 x \sec^2 x dx = \int u^2 du[/tex] when u= tan x.
I see
[tex]\int\tan^2 x\sec^2 x dx=\int \tan^2 x d(\tan x)=\frac{1}{3}\tan^3 x+C[/tex]
You forgot the x on the end of the tan, but other than that, its correct.
What is trig substitution?
Trig substitution is a technique used in calculus to simplify and solve integrals involving trigonometric functions. It involves substituting a trigonometric expression for a variable in the integral.
When should I use trig substitution?
Trig substitution is typically used when an integral involves expressions such as √(a²-x²) or √(a²+x²), where a is a constant. These types of expressions can be simplified using trigonometric identities and substituted for a variable to make the integral easier to solve.
What are the common trigonometric identities used in trig substitution?
The most commonly used trigonometric identities in trig substitution are sin²x + cos²x = 1, tan²x + 1 = sec²x, and 1 + cot²x = csc²x. These identities can be used to simplify expressions and make them easier to integrate.
Are there any tips for solving integrals using trig substitution?
One tip for solving integrals using trig substitution is to always rewrite the expression in terms of sine and cosine. This will often make it easier to identify which trigonometric substitution to use. Additionally, it may be helpful to draw a right triangle and label the sides and angles to visualize the substitution.
Can you provide an example of a trig substitution problem?
Sure! Let's say we have the integral ∫ √(4-x²) dx. We can use the trig substitution x = 2sinθ to simplify the expression to ∫ 2cos²θ dθ. Then, using the identity cos²θ = 1 - sin²θ, we can rewrite the integral as ∫ 2(1-sin²θ) dθ. Now, we can easily integrate to get the final answer of 2θ - ½sin(2θ) + C.
