Motion and Forces
  • Thread starter BuBbLeS01
A 3.54 kg block located on a horizontal floor is pulled by a cord that exerts a force F = 10.6 N at an angle theta = 15.0° above the horizontal, as shown in the Figure. The coefficient of kinetic friction between the block and the floor is 0.08. What is the speed of the block 3.9 s after it starts moving?
Xcomp= 10.6 cos 15
Ycomp= 10.6 sin 15
I don't know where to go from here :(
Answers and Replies
How about Newton's second law?
[tex] \sum_{i=1}^n F_i = ma[/tex]
so do I have to find the resultant vector or no?
learningphysics
4,099
Did you draw a diagram? Do [tex]\Sigma\vec{F} = ma[/tex] in the vertical and horizontal directions...
I don't know? I am so lost!
Okay so I have come up with the net force for the x and y directions...
Fxnet = Fx + Wx + Nx = Fx + 0 + Nx = max
Fynet = Fy + Wy + Ny = Fy - Wy + 0 = may
Is that set up right?
learningphysics
4,099
For the x-direction you wrote:
[tex]F_x + N_x = ma_x[/tex]
What is N_x ? Does the normal force act in the x - direction? what about the frictional force?
For the y-direction you wrote:
[tex]F_y - W_y + 0 = ma_y[/tex]
Hmmm... why didn't you put a normal force here?
Nx doesn't act in the x direction so I put it as 0...
so I have...
Fx/m = ax
For the normal force in the y direction I put 0...
(Fy-Wy)/m = ay
learningphysics
4,099
Hmmm... you're missing forces.
List all the forces acting in the x-direction.
List all the forces acting in the y-direction.
Forces in the x-direction:
Tension
Normal
Fricton
Forces in the y-direction:
Weight
Normal
Friction
Tension
learningphysics
4,099
There's no normal force in the x - direction. There's no frictional force in the y-direction.
So in the x-direction... you only have the x-component of tension, and the friction... write out the F=ma equation in the x-direction.
In the y-direction... you have the y-component of tension, gravity and the normal force... write out the F=ma equation in the y-direction.
Oh okay...that was a dumb mistake I made...
Fxnet = Tx + Fx = ma
Fynet = Ty - Wy + Ny = ma
learningphysics
4,099
Cool.. try to substitute the values of tension, friction, weight etc... into your equations...
I got the friction and weight but I m drawing a blank on how to calculate the tension?
learningphysics
4,099
Actually you have the components of tension in your first post. :wink:
okay so the fx = 10.6 cos 15 is actually the tension force not the friction force?
learningphysics
4,099
yes, 10.6 is the force the cord exerts... ie tension... so 10.6cos15 is the horizontal component... 10.6sin15 is the vertical component.
then how do I calculate the friction force. I know I have to use the Kinetic friction force of 0.08 but isn't there something else I have to do to it?
learningphysics
4,099
Frictional force = normal force * uk
uk is the coefficient of kinetic friction = 0.08
Thats what I thought but isn't the normal force in the y direction 0? So the frictional force would then be 0...that can't be right. I thought the normal force in the y firection was 0 because it lies in the y-axis.
learningphysics
4,099
No normal force isn't 0... the net force is 0 in the y-direction (ie ay = 0, may = 0)
so I put...
Fxnet= (Tx + Fx)/m = a
but for normal force is that equal wcos theta?
learningphysics
4,099
so I put...
You mean this:
[tex]\Sigma\vec{F_x} = ma_x[/tex]
so substituting into the left hand side
[tex]Tcos(\theta) - friction = ma_x[/tex]
Don't assume that... write the equation for [tex]\Sigma\vec{F_y} = m\vec{a_y}[/tex]
why is it - friction and not +?
Ty - Wy + Ny = may
Related Threads on Motion and Forces
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
