Horizontal Distance of Hammer Dropped from Roof: Solved
  • Thread starter Beretta
  • Tags
    Motion
In summary, the hammer slides down the roof at a constant speed of 4m/s. It travels 10m horizontally before it hits the ground.
Beretta
39
A worker on the roof of a house drops her hammer which slides down the roof at constant speed of 4m/s. Th roof makes an angle of 30 with the horizontal, and the lowest point is 10m from the ground. what is the the horizontal distance traveled by the hammer between the time is leaves the roof of the house and the time it hits the ground?
What happen here is that I assumed that theta is 60 since it makes an angle if 30 with the horizontal and since the object is sliding down. Thus it leaves the roof on a 60 degree angle.
vx = 4m/s cos 60 = 2m/s
vy = 4m/s sin 60 = 3.46m/s
x(t) = x0 + vxt
y(t) = y0 + v0t - (1/2)g(t^2)
10m - 3.46m/s(t) + (0.5)(9.81m/s^2)t^2 = 0
I am ending up with a negative root Delta.
May you help me pls?
Motion in 2 dimensions
try:
vx = 4 cos 30
vy = 4 sin 30
Why would the angle be 30 degree not 60 degree?
What you want is the angle that the hammer is moving with respect to the horizontal. THe hammer travels the same plane as the roof, which is sloped 30 degrees to the horizontal. THe 60 degrees is the angle made with a vertical line. IF you use the angle from vertical, you have to switch your sines and cosines.
You need to find the time of travel using your vertical information. It will send you into a quadratic solution. If you are getting a negative under the radical, it's probably because you are not recognizing that both acceleration and y-displacement are negative values (since you are calling initial y-velocity negative).
Should I leave it 30 then? I am really confused!
Try drawing it out. You can use either 30 or 60, but you must remember to use the right trignometric function to find the appropriate component.
Motion in two dimensions
Chi Meson and Moose are right. You should start this out by drawing the problem(always!). Watch your signs, you are in charge so you get to decide which direction is negative, however, you also have to answer to your instructor.
The important thing to be learned from this problem is that the speed is proportional to the length of the sides of the right triangle. Please remember this, think about it, and use it often so that you don't forget it.
Trigonometry can be very confusing at first, but if you bear this one thing in mind it will help you greatly; c^2 = a^2 + b^2.
Everything else in trigonometry is just a restatement of this.
To solve your problem you could use:
vx = 4 cos 30
vy = 4 sin 30
or
vx = 4 sin 60
vy = 4 cos 60
The result will be the same either way. It's not just a good idea, it's the law.
I am really greatful to everyone. Thank you all. One more question though, shouldn't be vx = -4 cos 30 and vy = -4 sin 30 since the object is sliding in the negative direction?
Anything you want, as long as you are consistent. Generally, left negative, right positive is the traditional system.
1. What is the horizontal distance of the hammer dropped from the roof?
The horizontal distance of the hammer dropped from the roof is the distance the hammer travels horizontally before hitting the ground. This can be calculated using the formula d = v * t, where d is the horizontal distance, v is the initial horizontal velocity, and t is the time the hammer is in the air.
2. How is the horizontal distance affected by the height of the roof?
The horizontal distance is directly affected by the height of the roof. The higher the roof, the longer the hammer has to fall before hitting the ground, resulting in a greater horizontal distance. This is due to the increased time the hammer has to accelerate horizontally.
3. What is the relationship between the horizontal distance and the angle of the roof?
The angle of the roof does not have a direct impact on the horizontal distance. However, if the angle of the roof is not perpendicular to the ground, it can affect the initial horizontal velocity of the hammer, which will then affect the horizontal distance traveled.
4. How does air resistance affect the horizontal distance of the hammer?
Air resistance can have a significant impact on the horizontal distance of the hammer. As the hammer falls, it will encounter air resistance, which will slow it down and decrease its horizontal velocity. This will result in a shorter horizontal distance traveled.
5. Can the horizontal distance of the hammer be calculated without knowing the height of the roof?
No, the horizontal distance cannot be accurately calculated without knowing the height of the roof. The height of the roof is a crucial factor in determining the horizontal distance, as it directly affects the time the hammer has to accelerate horizontally. Without this information, the calculation would not be accurate.
  • General Math
