Homework Help: Motion in a plane
  1. Sep 8, 2010 #1
    A particle of mass m is in the xy plane so that it's position vector is r = acoswti + bsinwtj, where a, b and w are positive constants a>b.
    (a)Show that,
    i) The particle moves in an ellipse
    ii) the force acting on the particle is always directed towards the origin
    (b) Find the,
    i) Kinetic energy of the particle at A(a,0) and B(0,b)
    ii) Potential energy at A and B
    iii) The total energy of the particle and show that it is always constant.
    2. Relevant equations
    3. The attempt at a solution
    (a)
    i) I know this is the equation of an ellipse: (x - h)2 / a2 + (y - k)2 / b2 = 1 but I find it hard to show the particle moves in an ellipse.
    ii) I differentiated twice to get a = -w2r so the minus sign shows that it is always directed to the origin.
    iii) For a force to be conservative, the curl must be equal to zero. I tried doing that and got zero.
    (b) I'm somehow stuck. I tried using 1/2mv2 but I don't know where to plug in the A and B.
    iii) I know I should add the potential and kinetic energy to get the total energy and differentiate it to get something without t, but since I would not get the P.E and K.E, I couldn't go any further.
  3. Sep 8, 2010 #2
    gabbagabbahey
    Re: Mechanics
    Well, if [itex]\textbf{r}(t)=a\cos(\omega t)\textbf{i}+b\sin(\omega t)\textbf{j}[/itex], what are [itex]x(t)[/itex] and [itex]y(t)[/itex]? What are [itex]x^2[/itex] and [itex]y^2[/itex]? Can you multiply each by some number, add together the results and get one?
    Good...
    Again, what are [itex]x(t)[/itex] and [itex]y(t)[/itex] if [itex]\textbf{r}(t)=a\cos(\omega t)\textbf{i}+b\sin(\omega t)\textbf{j}[/itex]?
    You should be able to answer this without plugging in any points (like A and B). What is [itex]\textbf{v}(t)[/itex]? What does that make the kinetic energy (as a function of time)? If [itex]\textbf{F}(t)=-m\omega^2\textbf{r}(t)[/itex], what is the potential that gives rise to this force? What do you get when you add the two together?
  4. Sep 10, 2010 #3
    Re: Mechanics
    Do you think what I did is right?
    i) I squared both each component of i and j and divided by a2 and b2 respectively to get 1.
    I assumed at A, the y component is zero, differentiated the x component, squared it and multiply by half the mass. Did the same at point B.
    [/QUOTE]
  5. Sep 10, 2010 #4
    gabbagabbahey
    Re: Mechanics
    You seem to be missing the point. If [itex]\textbf{r}(t)=a\cos(\omega t)\textbf{i}+b\sin(\omega t)\textbf{j}[/itex], then you can immediately say [itex]x(t)=a\cos(\omega t)[/itex] and [itex]y(t)=b\sin(\omega t)[/itex].
  6. Sep 10, 2010 #5
    Re: Mechanics
    Ok, I got that side.
    This is for getting the Kinetic energy at points A and B.
  7. Sep 10, 2010 #6
    gabbagabbahey
    Re: Mechanics
    Okay, and what were your results?
  8. Sep 10, 2010 #7
    Re: Mechanics
    I got it to be: 0.5m(aw2coswt)2 at A and 0.5m(aw2sinwt)2 at B.
  9. Sep 10, 2010 #8
    gabbagabbahey
    Re: Mechanics
    But at each point (A and B), [itex]t[/itex] will have a definite value....what value of [itex]t[/itex] makes [itex]\textbf{r}(t)=a\cos(\omega t)\textbf{i}+a\cos(\omega t)\textbf{j}[/itex]
    equal to point A [itex](a,0)=a\textbf{i}+0\textbf{j}[/itex]?
  10. Sep 10, 2010 #9
    Re: Mechanics
    But no t was given or told to be found in the question.....I think I'm confused.
  11. Sep 10, 2010 #10
    gabbagabbahey
    Re: Mechanics
    I think you're confused too:wink:
    At a particular time the particle will be at point "A" (and at some other time it will be at point "B"). Since you know the position of the particle at any time is [itex]\textbf{r}(t)=a\cos(\omega t)\textbf{i}+b\sin(\omega t)\textbf{j}[/itex], you can calculate what time the particle reaches "A" and what time it reaches "B".
