Calculating Time for Catching a Thrown Ball in a Hot Air Balloon
In summary, the problem involves a hot air balloon rising at 13m/s and a ball being thrown upwards at 21m/s. Using the kinematic equations, it is found that the time it takes for the passenger to catch the ball is approximately 4.29 seconds.
darklich21
43
A hot air balloon is rising at 16meters/second when it's passenger throws a ball straight up at 22meters/second. How much later does the passenger catch the ball?
From what I understand so far, they want time. From the problem I'm given the initial velocity (Vi) of the ball, and I know my final velocity at some point will be 0m/s because I will catch it. I know I have to use one or several of the kinematic equations, but I'm not quite sure where to start. Can anyone help?
Equations and steps are much appreciated
Vf=Vi + at
Vf^2=Vi^2 + 2ad
Df=Di + ViT + 0.5at^2
What is the initial velocity of the thrown upwards?
How much time it takes to reach the maximum height?
At that instant instant what is the distance between ball and balloon?
After that, the balloon rises with uniform velocity, and ball fall freely.
Well, initial velocity of the ball thrown upwards is given in the problem, 22m/s right?
Uh, Disntance, I used Vf^2=Vi^2 + 2ad. I made Vi=22m/s and Vf=0 since the ball is at its peak. I got d=24.69m
the time it takes to reach the maximum height, What equation would I use, is it Y=Y0 + ViT -0.5gt^2?
And where would I go from there?
Initially ball is in the balloon, which is rising with a velocity. It is thrown from the rising balloon. Then what is its initial velocity?
You can find the time to reach the maximum height by using
vf = vi - gt.
During this time distance traveled by the balloon is d = vb*t.
Distance traveled by the ball is given by
vf^2 = vi^2 - 2*g*s.
At that instant, the distance between balloon and the ball is (s - d) = y
At hat instant balloon is rising with uniform velocity and ball is falling freely. If they meet after time t, then
distance traveled by the balloon x = vb*t
and distance traveled by the ball is y - x = 0.5* g*t^2
Solve for t.
When talking about the initial velocity of the ball, since it's being throw from the rising balloon, are you saying the initial velocity of the ball is the speed of the rising balloon + the speed at which you throw it?
darklich21 said:
When talking about the initial velocity of the ball, since it's being throw from the rising balloon, are you saying the initial velocity of the ball is the same as the speed of the rising balloon?
Yes.
Ok apparently I got the answer wrong so let me show you what I did:
initial velocity of the ball when throw from the balloon= 13m/s
time to reach maximum height: Vf= Vi -gt
0=13m/s -9.8t
t= 1.3265s
distance traveled by balloon at this time: d=Vb x t
D= (13m/s)(1.3265s)=17.2449m
distance traveled by ball: Vf^2=Vi^2 +2ad
0=(13m/s)^2 + 2(9.8m/s^2)(d)
d= 8.6224m
difference between balloon and ball is 17.2449m - 8.6224m = 8.6225m
And then, I used the last equation to solve for time: (y-x) = X0 + V0t + 0.5gt^2
8.6225= 0 + 0 + 4.9t^2
t= 1.33s which was apparently wrong.
Any ideas on what I did wrong?
How did you get this one?
It should be 16 m/s + 22 m/s
Oops, sorry about that, see the way my homework computer program works is if i get the wrong answer, it changes the values. So if you don't mind, the balloon is rising at 13 m/s and the ball is throw at 21 m/s.
Alright, so I did this:
initial velocity of the ball when thrown from the balloon is 13m/s + 21m/s = 34 m/s
0=31m/s -9.8t
t= 3.1633s
D= (13m/s)(3.1633s)=41.1223m
0=(34m/s)^2 + 2(9.8m/s^2)(d)
d= 58.9795m
difference between balloon and ball is 58.9795m - 41.1223m = 17.857m
17.857m= 0 + 0 + 4.9t^2
t= 1.91s
which was apparently wrong, any ideas?
In the problem the velocity of the balloon is given as 16 m/s. You have taken 13 m/s. Which one is correct?
the 13 m/s, sorry about that, the problem switched it's numbers.
And the ball is being thrown up at 21 m/s, not 22m/s. My apologies.
I missed that equation, my bad. But isn't that the same equation as d= vb * t that I used earlier in the problem? What's the difference now?
When they meet, the displacement of balloon and the ball is the same. Displacement of balloon is d = vb*t
The displacement of the ball is
d = vi*t - 0.5*g*t2
Equate them and solve for t.
Alright so if i equate them to each other, I get the following:
(Vb*t)=ViT -0.5gt^2
Using some algebraic manipulation, i get the following:
T(Vb-Vi)= -4.9T^2
I divide both sides by T and get:
Vb - Vi= -4.9T
Vb= initial velocity of balloon= 13m/s
Vi= initial velocity of ball = 13+21= 34m/s
therefore:
(13-34)=-4.9T
T=4.29seconds
is this right?
I think it is right.
ouch, it's not. I really don't know where I went wrong in this problem. Any ideas?
No idea. What is the answer.
1. What is motion in a straight line?
Motion in a straight line is a type of motion where an object moves along a straight path without changing direction.
2. How is motion in a straight line different from other types of motion?
Unlike other types of motion, such as circular or projectile motion, motion in a straight line does not involve any changes in direction or acceleration.
3. What factors affect an object's motion in a straight line?
The main factors that affect an object's motion in a straight line are its initial velocity, the forces acting upon it, and the mass of the object.
4. How is the speed of an object in motion in a straight line calculated?
The speed of an object in motion in a straight line can be calculated by dividing the distance traveled by the time it takes to travel that distance. The formula for speed is speed = distance/time.
5. What is the difference between speed and velocity in motion in a straight line?
Speed is a measure of how fast an object is moving, while velocity is a measure of both speed and direction. In motion in a straight line, an object's velocity will be the same as its speed if it is moving in a constant direction.
