Motion in two dimensions basketball dunk
In summary, a basketball star covers 2.40 m horizontally in a jump to dunk the ball. His motion through space can be modeled precisely as that of a particle at his center of mass. His center of mass is at elevation 1.02 m when he leaves the floor. It reaches a maximum height of 1.90 m above the floor and is at elevation 0.910 m when he touches down again.
ppxrare
A basketball star covers 2.40 m horizontally in a jump to dunk the ball (see figure). His motion through space can be modeled precisely as that of a particle at his center of mass. His center of mass is at elevation 1.02 m when he leaves the floor. It reaches a maximum height of 1.90 m above the floor and is at elevation 0.910 m when he touches down again.
(a) Determine his time of flight (his "hang time").
(b) Determine his horizontal velocity at the instant of takeoff.
(c) Determine his vertical velocity at the instant of takeoff.
(d) Determine his takeoff angle.
(e) For comparison, determine the hang time of a whitetail deer making a jump (see figure above) with center-of-mass elevations yi = 1.20 m, ymax = 2.45 m, and yf = 0.800 m.
I tried to think about the question but I'm not getting anywhere, by time of flight do they mean time till he reaches max height or till he reaches hoop and comes down again and I am confused by the elevation
Time of flight = total time from when he leaves the ground to when he comes back down. As far as the elevation is concerned, you simply have two different values of delta-y. So, you need to fully calculate the time to go from 1.02m to 1.90m, then from 1.90m to 0.91m and add those two together. You'll do the same with the deer in part e.
how do I calculate the time though? I don't think I have enough information as I don't have initial velocity
No - you're supposed to calculate initial velocity for parts b & c. You do have equations that relate distance, time, acceleration (hint #1: what is the only acceleration involved?), initial velocity, and final velocity (hint #2: what is the velocity in the y-direction at the top of his arc?).
ok so far this is what I have thought of, delta y = 0.88m final y velocity is 0 (top of arc) and acceleration is -9.81
I used these two equations
delta y = Viyt -9.81t^2
Vyf= Vyi + at
I substituted for Viy but I got the time negative what am I doing wrong?
Your delta-y and finaly y velocity are correct, and the second equation is correct. And you obviously know that a is -9.81m/s^2. But, your first equation is slightly off. It is 1/2*at^2 - you forgot the 1/2.
But, I think you need to first use the equation that relates the final and initial velocities to the distance and acceleration. Since you already have three of those variables (a=-9.81m/s^2, delta-y=0.88m, and v_yf=0), it should be easy to find v_yi and then plug that value into one of your equations to find the first t.
thanks a lot man, I got it correct. Would appreciate some more help in another thread:P
1. What is the physics behind a successful basketball dunk?
A successful basketball dunk is dependent on a combination of factors such as the player's height, speed, and strength, as well as the ball's trajectory and velocity. When a player jumps to dunk the ball, they exert a force on the ball that changes its velocity and direction, ultimately resulting in a successful dunk.
2. Can you explain the concept of projectile motion in a basketball dunk?
Projectile motion refers to the curved path that an object follows when it is thrown or projected near the Earth's surface. In a basketball dunk, the player and the ball both follow a projectile motion. The player's jump provides an initial upward velocity, while the ball's release angle and initial velocity determine its trajectory.
3. How does air resistance affect a basketball dunk?
Air resistance, also known as drag, can have a significant impact on a basketball dunk. As the ball moves through the air, it experiences a drag force that opposes its motion. This force can slow down the ball and alter its trajectory, making it more difficult for a player to successfully dunk the ball.
4. What role do forces play in a basketball dunk?
Forces play a crucial role in a basketball dunk. The player exerts a downward force on the ball when they jump, which changes the ball's velocity and direction. Additionally, gravity exerts a constant downward force on both the player and the ball, causing them to follow a curved path towards the ground.
5. How does the angle of release affect a basketball dunk?
The angle of release is an essential factor in determining the success of a basketball dunk. A higher release angle can result in a more significant vertical displacement of the ball, making it easier for the player to dunk. Conversely, a lower release angle can result in a shorter vertical displacement, making it more challenging to successfully complete a dunk.
12K
