Binary Star Explosion: Calculating Total Energy and Period
In summary, the conversation discusses a binary star system in which one star explodes and the two stars become equal in mass. The total energy, angular momentum, and period of the binary star before the explosion are calculated. The conversation also touches on the equivalent single particle system and how it can be used to show that the binary star will remain bound after the explosion. The concept of potential energy and its relation to force is also discussed.
bon
559
Two individual stars in a binary system (m1=mo, m2=2mo) are in circular orbit about their common centre of mass and are separated by a distance ro. At some stage, the more massive star explodes - resulting in the two stars having equal mass after the explosion
(a)Calculate the total energy, angular momentum and period of the binary star as viewed in the ZMF before the collision.
(b)Calculate the total energy and period of the equivalent single particle system orbit, before the explosion.
(c) Using the equivalent single particle system or otherwise, show that the binary star will remain bound after the explosion.
(a)
So is the total energy just the sum of the energy for each star?
I defined PE to equal 0 at one star and found total energy = -Gmo^2/ro
How do you do it for angular momentum? Just find the two individually, note they are in opposite direction, and add?
I worked out T = 2/3 pi ro / (1/3 Gmo/ro)^1/2 Is this right?
(b) I am using F int = ur'' where u is reduced mass, r relative position vector..
Using this method i get E total to be -1/3 Gmo^2/ro..which isn't equal to the above, why?
Also I get T = 2/3pi ro / (Gmo/ro)^1/2 which again isn't equal to the above.. :S
(c) Not sure how to do this...
Thanks!
Start with the two individual bodies first. They interact, and there is no external force. Choose a system of reference with the centre of mass as origin.
Both planets orbit around the CM along their individual circles, but with the same angular velocity. What are the radii? What is that angular velocity?
What is the KE of the whole system?
As for the potential energy of a system of material points, take into mind, that the negative gradient of the potential energy is the force, and the gradient is a function of the coordinates of both bodies. It can be shown for this binary system that PE =-(G m1 m2 )/r0. It is zero when the stars are at infinite distance apart, not at one star, where r0=0.
The angular momentum is m r^2 w at a circular orbit, but it is not opposite for the individual stars. Would the CM stay in rest if they move in opposite direction?
As for the equivalent single particle system, you have a "reduced" or "effective" mass u= 2/3 m0, orbiting around a mass of 3 m0. Calculate angular velocity, energy and angular momentum according to this.
ehild
Likes 1 person
Ah ok this is really helpful thanks. For now, just stuck on one bit of what you say about potential energy.
So i know that for the start with mass 2mo, F = Gmo(2mo)/ro^2
so the PE is the -grad of this.but how do i take -grad of F? I haven't done grad in polar coords yet.. :S
Thanks
Thanks
No, the FORCE can be obtained by taking the gradient of the potential energy. Taking the gradient makes a vector from a scalar and force is a vector and potential energy is a scalar.
What is a binary star system?
A binary star system is a pair of stars that orbit around a common center of mass. These stars are held together by their mutual gravitational attraction and can either be physically connected or just orbiting each other at a distance.
How do binary stars form?
Binary stars can form in several ways. One way is through fragmentation of a molecular cloud, where two clumps of gas and dust collapse and form two stars. Another way is through the capture of a passing star by another star's gravitational pull.
What is the motion of a binary star system?
The motion of a binary star system is a combination of both stars' orbits around each other. The center of mass of the system remains the same, but the two stars will orbit around it at varying speeds depending on their masses and distances from each other.
How is the mass of a binary star system calculated?
The mass of a binary star system can be calculated by observing the orbital motion of the stars. By measuring the orbital period and distance between the stars, scientists can use Newton's laws of motion and universal gravitation to calculate the combined mass of the system.
What are the implications of studying binary star systems?
Studying binary star systems can provide valuable insights into stellar evolution, as well as the dynamics of multiple star systems. It can also help us understand the formation and evolution of planets, as many exoplanets have been discovered orbiting binary stars. Additionally, binary stars can serve as important tools for measuring distances and studying the effects of gravity on celestial bodies.
