Motion of charged particles
  • Thread starter BOYLANATOR
BOYLANATOR
198
This is a problem I was thinking about which I haven't come across in my course.
Two particles with mass, m, and a positive charge, q, are separated by a distance r0. One particle is unable to move while the other is released and is repelled. Find an equation for the motion of the particle.
F=q2/cr2
a=F/m
The problem I have in working out the acceleration at any time here is that r is a time dependent variable.
Although this seems like a pretty important thing to know how to calculate I end up going around in circles with the maths.
Answers and Replies
voko
6,054
391
This is not a simple problem. Even if we assume that the accelerating particle does not radiate energy (which in reality it would do), we still end up with a differential equation. You can get this equation from conservation of total energy. The resultant equation can be integrated, but it will be a complicated expression, where the distance depends on time implicitly.
gneill
Mentor
20,945
2,886
You can easily find the velocity at some position r via the change in potential energy that occurs in moving from position ro to new position r. That'll give you some expression:
##v = \sqrt{f(r)}##
where f(r) is a function of r (it's for you so work out!).
Then make v = dr/dt, shuffle to group the appropriate variables and integrate both sides. That'll leave you with an expression of the form t = g(r), for g some function of r (again, for you to work out).
As for finding r in terms of t, that is, r(t), well you might find that solving t = g(r) for r is not trivial. Good luck!
Suggested for: Motion of charged particles
  • Last Post
  • Last Post
10K
9K
