Does Earth's Rotation Impact Airplane Travel and Space Launches?
In summary, planes do not take into account the Earth's rotation when flying because the atmosphere moves at a similar speed. However, satellites and space launches do take advantage of the Earth's rotation by launching from locations closer to the equator. Flying over the northern pole area is beneficial for some flights due to it being the shortest path, not because of the Earth's rotation.
rock.freak667
6,223
31
If the Earth spins at a very fast rate (tis like 300km/s or something like that I think) do Aeroplanes take this into account and by that do I mean if they move in the direction of the Earth's rotation to decrease the power required by the engines to produce the required speed.
Not to first order, because the atmosphere moves at about the same speed as the earth. The high altitude "jet stream" moves at ~100 mph from West to East, so that air travel is faster from West to East. The jet stream is probably related to the Coriolis force due to the Earth's rotation. Satellites are launched over the sea from Florida to take advantage of the ~800 mph velocity of the Earth.
Or, no for the same reason you don't take it into account when throwing a ball.
So they don't because planes don't fly high enough to take advantage of the Earth's rotation?
There is no such thing as flying high enough to take advantage of the Earth's rotation. The atmosphere is basically attached to the earth, so you either fly in it or you fly out of it. If you fly in it, you don't take advantage of the Earth's rotation, if you fly out of it (which isn't really flying anymore) you do.
But flying over the northern pole area of the globe (for Northern Hemisphere flights) does have an advantage for some flights, no?
That's just because it it the shortest path. That has nothing to do with rotation.
On the other hand, space launches do utilize the effect. That's why spaceports are located as close as possible to the equator.
What is the motion of the earth?
The earth has two main motions: rotation and revolution. Rotation is the earth spinning on its axis, which takes 24 hours to complete. Revolution is the earth's orbit around the sun, which takes 365.25 days to complete.
How does the motion of the earth affect us?
The earth's motion affects us in various ways. The rotation of the earth causes day and night, while the revolution of the earth around the sun results in the changing of seasons. The earth's tilt also affects the amount of sunlight and temperature in different regions, leading to varying climates and weather patterns.
What evidence do we have of the earth's motion?
There is a vast amount of evidence supporting the earth's motion, including the observation of celestial objects moving across the sky, the changing of constellations throughout the year, and the occurrence of eclipses. Additionally, technological advancements such as satellites and space probes have provided concrete data and images of the earth's rotation and revolution.
How does the motion of the earth impact time?
The earth's motion is directly related to the measurement of time. The rotation of the earth on its axis is the basis for the 24-hour day, while its revolution around the sun is the basis for the 365.25-day year. The earth's motion also plays a role in the creation of time zones and the concept of leap years.
What are the potential consequences of changes in the earth's motion?
Any significant changes in the earth's motion could have severe consequences. Alterations in the earth's rotation could lead to changes in the length of days and nights, while changes in its orbit could impact the amount of sunlight and temperature on earth. These changes could have significant impacts on ecosystems, weather patterns, and human activities such as agriculture and transportation.
