Motion Question
  1. Feb 23, 2006 #1
    I solved a problem my teacher assigned, but I don't know if I did it right. The question is:
    A person standing on the roof of a building throws a brick straight down at 7 m/s. THe brick hits the ground 4 seconds later.
    Calculate:
    a) The velocity at which the brick hits the ground (I got 46.24 m/s)
    b) The height of the building (I got 106.48 m)
    c) If the brick is thrown upward instead, at 7 m/s, how much longer will it take to hit the ground? (I said it would take 11.108 s)
    Thanks.
  3. Feb 23, 2006 #2
    what did you receive for time? 7m/s is initial velocity right?
  4. Feb 23, 2006 #3
    It hit the ground 4 seconds after, so that's the time... and 7 m/s is the initial velocity.
  5. Feb 23, 2006 #4
    I agree with (a) and (b), but I got a different number for (c).
  6. Feb 23, 2006 #5
    What was your number? I got mine by getting the time it traveled up at 7m/s. It hit zero velocity, and started accelerating towards the ground by the acceleration due to gravity (9.81 m/s2). Then I calculated how many seconds it took from zero velocity to the ground. Is my method even correct?
    Edit: Sorry, I wrote down what I did wrong... this isn't the method I used...
  7. Feb 23, 2006 #6
    Well I don't want to give you the answer :wink:
    You need to use the formula:
    [tex]x(t) = \frac{1}{2} a t^2 + v_0 t + x_0[/tex]
    and pick appropriate values for [itex]a[/itex], [itex]v_0[/itex], and [itex]x_0[/itex]. Your specific values will depend on your coordinate system, of course. Just make sure that you're explicit with where the origin of your coordinate system is and which way you're calling positive, then make sure that all your numbers are consistent with that coordinate system.
  8. Feb 23, 2006 #7
    If you're saying that the acceleration is negative then you're saying that gravity pulls the brick in the negative x direction. This means that your initial velocity should also be negative.
    Like I said above, it's important to be very careful about what your coordinate system is and make sure that all the values you're using make sense in that coordinate system. That's realy the hardest part with these problems is making sure that you're consistent.
Similar Discussions: Motion Question
  1. Motion question (Replies: 2)
  2. Motion question - (Replies: 2)
  3. Motion Questions (Replies: 20)
  4. Motion Question (Replies: 3)
  5. Motion Question (Replies: 4)
Loading...
