Building a rat trap operated car
In summary: Have someone hold the trap while you measure the distance the car has traveled.In summary, a rat-trap operated car can be used to track the distance and speed of a rat or mouse. However, finding this information is a matter of experimentation and is not always accurate.
Aaron321
hey every1.. at the moment for a school project a group of mates and i are building a rat trap operated car. This is made by obviously a rat trap with about 5mm diamater front wheels and cds as the rear wheels... this is just a quick explanation. what i need to do is find out how far the car will go and what speed it will be.
i thought that the distance = circumfrence of the back wheels * revolutions of the axle (has the string tied to t).
however I am pretty sure this is just finding out the distance the car will travel from start to when the string is fully unwound (not past that). so now I am abit confused and trying to find out a way to find out the distance covered from the momentum. but not sure so if anyone has any suggestions it would be appreciated. cheers
note - info on rat/mouse trap operated cars can be found from a google search.
Aaron321 said:
… so now I am abit confused and trying to find out a way to find out the distance covered from the momentum.
Hi Aaron321! :smile:
Finding the distance from the momentum is really a matter of experiment.
On a flat floor, theoretically the rat-trap should stay at the same speed, and go an infinite distance (Newton's first law), whatever momentum it has
In practice, it depends on friction, aerodynamic drag, and how wobbly your cds are! :smile:
It also depends if you have a one way bearing between the axle and spindle. If the trap is completely sprung, then the car would go no where from momentum unless there's a one way bearing allowing the axle to continue moving.
If you have a force gage, just push the car with it and read the force it takes to push it at a good speed. Then just fudge the numbers and calculate a guess. If you want super accuracy your going to have to do what tiny-tim suggested experiment.
1. How does a rat trap operate a car?
The rat trap acts as the main source of power for the car. When the trap is triggered, it releases a spring or other mechanism that propels the car forward.
2. What materials are needed to build a rat trap operated car?
You will need a rat trap, wheels, a chassis, an axle, and materials for the body such as cardboard or plastic. Other materials like rubber bands, tape, and glue may also be helpful.
3. Can any type of rat trap be used?
Yes, any type of rat trap can be used as long as it has a strong spring or mechanism that can create enough force to move the car.
4. How do I make sure the car goes in a straight line?
One way to ensure the car goes in a straight line is to attach the wheels to the axle at an equal distance from the center of the car. You can also use a guide or track to keep the car on a straight path.
5. Can I modify the design of the rat trap operated car?
Yes, you can modify the design to fit your preferences. You can change the size, shape, and materials used to make the car. Just make sure to keep the main mechanism of the rat trap intact to ensure it can still operate the car.
  • Mechanical Engineering
  • Mechanics
