Motional EMF Question
  • Thread starter Seiya
Hey lads, if anyone can, please check If im correct... Thanks :)
A 100 turn circular coil has a diameter of 2 cm and a resistance of 50 Ohms. The plane of the coil is perpendicular to a uniform magnetic field of magnitude 1 T. The direction of the field is suddenly reversed.
(a) Find the total charge that passes through the coil. If the reversal takes 0.1 s, find
(b) the average current in the coil and
(c) the average emf in the coil
So I got...
I= dq/dt
Е=-dф/dt
Edt/R=dQ
Integral of dQ = Q = -1/R (int from ф0 to фf) dф
= -1/R(фf-ф0) = -(delta)ф/R
ф0 (field goes inside, n vector goes inside) = NBAcos() = +NBA
фf (field goes outside, n vector goes inside) = NBAcos() = -NBA
So Q = - (-NBA-(NBA))/R = 2NBA/R = .001256C
(b) I = dQ/dt and dt= .1s
= .01256A (since dQ = Q because Q0= 0 )
(c) E=IR = 0.626V
Am I correct? If not can you please point out any mistakes I have made... thanks i very much appreciate it =)
Answers and Replies
nrqed
293
So I got...
I= dq/dt
Е=-dф/dt
Edt/R=dQ
(c) E=IR = 0.626V
This looks completely right to me.
Related Threads on Motional EMF Question
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
