Motor and required torque.
So I need a motor that is able to provide [itex]\begin{equation}0.412Nm\end{equation}[/itex] of continuous torque (to overcome rolling resistance).
A BLDC I have is rated at [itex]\begin{equation}285W\end{equation}[/itex] and [itex]4700Kv (rpm/V)[/itex].
So I was wondering if my calculations are correct.
Using the relationship between Torque and Power and angular speed
[itex]
\begin{equation}
\begin{split}
\omega &\approx 700rads^{-1} \approx 6700rpm\\
T &= 0.412Nm \\
P &= 285W
\end{split}
\end{equation}
[/itex]
From this get the voltage from the motor specs
[itex]
\begin{equation}
\begin{split}
V &= \frac{6700}{4700}\\
&= 1.42V
\end{split}
\end{equation}
[/itex]
So now using the fact that
[itex]
\begin{equation}
\begin{split}
K_t &= \frac{1}{K_v}\\
T &= K_t i
\end{split}
\end{equation}
[/itex]
Therefore
[itex]
\begin{equation}
\begin{split}
i &= K_v \times T\\
&= 4700 \times 0.412\\
&= 1936A
\end{split}
\end{equation}
[/itex]
This result makes no sense because that is a tonne of current.
Assuming 100% efficiency (P = IV)
[itex]
\begin{equation}
\begin{split}
285 &= i \times V\\
i &= 196A
\end{split}
\end{equation}
[/itex]
Which again seems really really high.
Am I missing something somewhere? Will the motor not draw that amount of current at the given loads/speed? I am confused as I think the equations are correct....?
Answers and Replies
russ_watters
Mentor
21,182
7,995
Is 6700 rpm what you need? What is the rated voltage, rpm and torque of the motor? I think you just proved that the motor is either too small to meet your needs or needs to be geared down.
And it won't produce 285W at any voltage, only at its rated rated voltage. The limiting factor is actually the Amps.
6700rpm is the needed speed yes (to turn a wheel of 120mm fast enough to give the required forward speed)
I cannot find a rated voltage/rpm/torque of the motor as it is a brushless DC motor. ie I get given a Kv value and a max power.
Say for arguments sake I have a 'magic' power supply that will give any amount of current/voltage I require.
Or i what you are saying that because of the 1936A I calculated the Kv value is too large (hence Kt too small) and thus the motor will not meet the specifications without a gear reduction?
EDIT:My bad I meant Kv too small giving a Kt that is too large. Reducing current = decrease Kt
EDIT2: Just to make it a bit clearer the absolute necessary parameter is the 0.413N. The speed was calculated using the maximum power and this torque so the 6700 can change.
CWatters
2,312
Your first part is correct...
Power = Torque (Nm) x angular velocity (rads/s)
So you need a motor capable of delivering..
RPM = 6700 = 700 rads/s
Torque = 0.412 Nm
so
Power = 0.412 * 700 = 288W
eg I agree with you so far.
Then I would look at data for the motor efficiency. If the motor is say 80% efficient the power drawn will be..
288 x 100/80 = 360W
Will the controller handle that ok?
If the motor you have in mind has a Kv of 4700 then the voltage does indeed work out at
6700/4700 = 1.42V
The current draw would be roughly
Power in/voltage = 288/1.42 = 202A
Now it's unlikely you will find a motor that is 80% efficient at 1.4V and 200A so it sounds like the motor constant is too high for your application. Consider a reduction gearbox to allow you to operate the motor at higher voltages, higher rpm, lower current yet still achieve the required rpm at the output of the gearbox. A ratio of around 10:1 might do it.
Failing that.. What voltage range is the controller designed to operate from and what voltages do you have available?
Suppose your controller and power supply was ok at 12V, then a KV of around
6700/12 = 560
would be better. Perhaps slightly higher to ensure the required max rpm can be achieved under load. Check the data for the motor carefully.
The current draw would then be around..
360/12 = 30A.
If it helps...Rare earth motors generally have lower Kv than ferrite.
EDIT: Actually a 10:1 gearbox would not work. To achieve an output of 6700rpm the motor would need to turn at 67,000rpm which is a bit too high for most motors/controllers.
Oh so that's where I was going wrong. I was trying to take the rpm and calculate torque rather than setting my torque and rpm then calculating power.
The method you described makes sense. Just to verify something though,
Say my motor has a 80mOhm resistance (most bldc have around this) then
P= I^2 * R
Will get the power loss due to the windings within the motor so at the first 202A the power loss would be approximately 3.26kW, which when I am only getting out 288W my efficiency would become 8.1% which as you said is not 80%.
Using the second approximation (30A) the power losses become
72W which is much more realistic infact = 80% efficicent.
Are the comments made above correct?
CWatters
2,312
Basically correct. There are other losses in addition to I^2R which can become significant once the efficiency is getting up towards 90%.
One advantage of a rare earth magnet motor is that the higher flux means less turns are required to achieve the same back emf at the specified RPM. If fewer turns are needed you can switch from a long thin wire to a short fat wire. That reduces the winding resistance. I have some brushless motors for competition model aircraft that have just 2 (two) turns. Companies like Aveox make motors with just 1 (one) turn or indeed 1.5 turns.
Related Threads on Motor and required torque.
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
