Motor of linear aceleration by forces of spin by raaaid
In summary, the speaker had a patent in 2002 that they lost due to not paying the 20 euro fee and then retired in 2003. The patent was for a device that could repel gravity, which the speaker believes could potentially be a time machine. The device involved spinning two motor cylinders in opposite directions while also moving the spinning axis. The speaker believes there is a connection between their psychotic episodes and forgetting about the patent. The patent was published in a Spanish publication in 2002 and the retirement of the solicitude was published in 2003.
sea_wizard
heres a patent i got in 2002 of which first i lost property for not paying the 20euro it costed and second got retired in 2003, deciding not go on with the reclaim.
imagine two motor cylinders that beside its normal armonic movement can spin.
imagine the cilinders as two cigaretes you hold in each hand, let's take a look at one of the cigaretes: you hold it in the middle with two fingers pointing with the filter at 3 o clock then you make it spin until 9 (always holding it in the middle), then from 9 to 12 at the same time you spin it you displace the spinning axe as away from the filter as posible (you spin it and push it at the same time) then from 12 to 3 recover the spinning axe to the center of the cigarete, and then so on again.
physical explanation: imagine two persons very strong standing in a platform in empty espace. They have stones tigth to the end of ropes and start making the stones turn faster and faster compensating each other reaction, they also give rope away so the platform starts balancing back and forward, now imagine that when the stones are at 3 and 9 going to 12 the two persons recover suddenly all of the rope ending the stones above their heads being the axe of spin and the center of gravity in the same vertical.
by the way according to mr raaid mustafa if you buid a device that can repel gravity what you are really building is a time machine.
still strikes me the coincidence of the name and the believe that gravity is the expansion of matter
the reason for forgetting this patent is that when i got first the property of the patent i got my first psycotic episode (unusual 28 with no family antecedents).one year later after calling the office of patents they explain me two steps to take first retiring the patent second reclaim, first step is been taken then have my second psycotic episode as i don't want a third my claim of the patent will not be taken ever more
Do you have the numbers of the patents? I'd be interested in reading them.
is a spanish patent
Nº U200102856 published the concession in the bopi 16-11-2002
the retirement of the solicitude of "modelo de utilidad" will be published in the bopi 16-11-2003
Related to Motor of linear aceleration by forces of spin by raaaid
1. What is the "Motor of linear aceleration by forces of spin by raaaid"?
The "Motor of linear aceleration by forces of spin by raaaid" is a theoretical concept proposed by scientist Raaaid. It suggests that the linear acceleration of an object can be achieved through the application of rotational forces.
2. How does the "Motor of linear aceleration by forces of spin by raaaid" work?
The motor works by utilizing the principle of angular momentum, where the rotational force applied to an object can result in linear acceleration. This concept is similar to how a propeller on a boat or airplane works.
3. Can the "Motor of linear aceleration by forces of spin by raaaid" be applied in real-life situations?
Currently, the motor is still a theoretical concept and has not been proven to work in practical applications. However, further research and development could potentially lead to its implementation in certain industries.
4. What are the potential benefits of using the "Motor of linear aceleration by forces of spin by raaaid"?
If successfully developed, this motor could potentially offer a more efficient and sustainable way of achieving linear acceleration compared to traditional methods. It could also have applications in areas such as transportation and robotics.
5. Are there any challenges or limitations to the "Motor of linear aceleration by forces of spin by raaaid"?
As with any new technology, there are challenges and limitations that need to be addressed. Some potential challenges with this motor could include the complexity of design and the need for precise control of rotational forces. Additionally, further research and testing are needed to determine its feasibility and practicality.
  • Other Physics Topics
  • General Engineering
  • Quantum Physics
  • Beyond the Standard Models
