Solving Mouse Noise Problem on Windows XP
  • Thread starter Mudvaynelethaldosage
  • Tags
    Noise
In summary, the speaker noise caused by the mouse moving was resolved by rerouting the mouse wire away from other wires. However, occasional issues with the mouse not working after rebooting may be due to a hardware problem, such as dirt on connections or electrical interference.
53
My mouse is causing noise in my speakers whenever I move it. I can't exactly explain the noise, but it's quite and wouldn't be noticed if perhaps the television was on or I had an mp3 playing.
I tried muting the speakers from the volume control panel in windows XP, but I could still hear the noise. The speakers and mouse are both attached to the motherboard. I just got the thought that it's electrical interferance and plan to reboot and reroute the mouse wire away from other wires.
Also, sometimes when I reboot, the mouse doesn't work so I have to reboot again. The cursor just stays in the middle of the screen so I have to use the keyboard to reboot. I've thought this was a driver problem, but my pc says the driver is the best possible one, even though I tried to install the driver that came on cdrom with the mouse.
Any ideas?
Computer science news on Phys.org
wow, I rerouted the mouse wire and the noise stopped. It was all wrapped up in the speaker wires. problem solved except for the booting without the mouse working problem, but that doesn't happen too often.
have you opened your PC up and looked at the motherboard? Sounds like you have a problem there.. could be some dirt on one of the connections, or even a short of some short.. Could be a multitude of things, I would say tho its sounds like hardware problems
ahh... lol.. makes sence.. some EM interferance onto your speaker wire..
What is causing the mouse noise problem on Windows XP?
The mouse noise problem on Windows XP is typically caused by outdated or corrupt drivers, conflicting software, or physical issues with the mouse or computer hardware.
How can I fix the mouse noise problem on Windows XP?
To fix the mouse noise problem on Windows XP, you can try updating your mouse drivers, running a virus scan, closing any conflicting software, or replacing the mouse or computer hardware if the issue is physical.
Why is the mouse noise problem only happening on Windows XP?
The mouse noise problem may only be happening on Windows XP because it is an outdated operating system and may not be fully compatible with newer mice or drivers. Additionally, other software or hardware on your computer may be causing conflicts.
Is there a way to prevent the mouse noise problem from occurring on Windows XP?
To prevent the mouse noise problem from occurring on Windows XP, make sure to regularly update your drivers, run virus scans, and avoid installing conflicting software. If the issue persists, consider upgrading to a newer operating system.
Can I fix the mouse noise problem on Windows XP without replacing any hardware?
In most cases, the mouse noise problem on Windows XP can be fixed without replacing any hardware. However, if the issue is caused by physical damage to the mouse or computer hardware, replacing these components may be necessary.
  • Computing and Technology
