Can a Multi-Position Solenoid be Created with a Permanent Magnet Core?
  • Thread starter oronymo
  • Tags
    Solenoid
In summary: Something like this could be done with a small number of coils.Maybe think about a rachet mechanism in combination with your bidirectional solenoid. Move the shaft in rachet steps...A solenoid decreases its force with displacement whereas a spring increases its force with displacement. It seems to me if you were to put the spring back in, the more current you put through the coil, the greater the displacement that would result. At a particular current, the displacement should be constant and stable.A solenoid decreases its force with displacement whereas a spring increases its force with displacement. It seems to me if you were to put the spring back in, the more current you put through the coil, the greater the displacement that
oronymo
Hi-
I'm trying to build a simple linear motion control using a solenoid. I've replaced the typical steel core for a permanent magnet core so that I can both push the armature out and pull it back in by flipping polarity (and without using any springs). This works nicely.
Unfortunately, it still can only go full out or full in, like a regular solenoid. I would love to be able to add a stopping point mid-way. So in effect, I could 3 positions - In, halfway out, all the way out - and still be able to go both directions.
Is this possible? Perhaps with a core that is some combination of reversed polarity magnets and a steel core? Or with a steel ring that acts like a mid-point latch?
Any ideas are helpful.
Thanks!
hi there
just a random thought ... what about multiple coils that you could control current clow direction individually or combined. ?
Dave
I had the same idea, and I'm pretty sure that would work, the problem is that it increases the complexity of the control circuit (I would now have to control multiple EM coils and with good timing). The goal is create a large matrix of these and each additional complexity in control will result in exponential complexity in the whole system. But it is a fallback option.
oronymo said:
Hi-
Thanks!
Hmm interesting idea. The downside is that to keep it at the midpoint you would have to supply continuous current, which is not ideal.
Understood, however if a solenoid were constructed with a spring for each direction were at zero displacement when the core was also at zero displacement, it should work.
1. What is a multi-position solenoid?
A multi-position solenoid is an electromechanical device that uses an electric current to generate a magnetic field and produce linear or rotary motion. It typically has multiple positions that can be switched between by controlling the current flow.
2. How does a multi-position solenoid work?
A multi-position solenoid works by converting electrical energy into mechanical energy. When a current is applied, the solenoid's coil creates a magnetic field that attracts or repels a plunger or armature, causing it to move and change the position of the solenoid. This movement can be used to activate or deactivate various components in a system.
3. What are the applications of multi-position solenoids?
Multi-position solenoids have a wide range of applications in various industries, including automotive, aerospace, medical, and manufacturing. They are commonly used in valves, actuators, switches, and other devices that require precise and reliable movement control.
4. What are the advantages of using a multi-position solenoid?
One of the main advantages of a multi-position solenoid is its ability to provide precise and repeatable movement control. It is also compact, lightweight, and energy-efficient compared to other mechanical solutions. Additionally, it can operate in harsh environments and can be easily integrated into automated systems.
5. How do I choose the right multi-position solenoid for my application?
When selecting a multi-position solenoid, it is important to consider factors such as the required stroke length, force and speed requirements, voltage and current ratings, and environmental conditions. It is also recommended to consult with a solenoid specialist to ensure the best fit for your specific application.
  • Electrical Engineering
  • Classical Physics
