Essential Multimeter Features for Accurate PC Repair: A Guide for Techs
  • Thread starter biferi
In summary, it is recommended to use a clamp ammeter to measure the current drawn by a device, rather than trying to measure the current capacity of a household outlet. The current rating of an outlet is predetermined by the hardware and is not something that can be easily measured. It is also not necessary to measure this as the maximum current allowed for a household installation is already predetermined and should not be exceeded.
biferi
191
I am a PC Repair Teck and I need a good Mulimeter.
But I am going to be taking Readings of House Hold Voltage and Currents as well.
So I need it to be able to be able to Read A.C. Amps up to 15 Amps and maybe above.
I need it to Take Resistance Readings from as Low as 200 mOhm to 20 MOhm.
And I would like it to have an Imput Impedance of 10 MOhm.
I need it to take Continuity Readings to.
I can not find one for this and even the High end ones won't let me Read A.C. Amps up to 15 Amps.
Can anyone help?
Can anyone help?
You'll probably need to get two meters, since I don't think there is one that will do everything you're asking. To read household currents, get a clamp ammeter. Sears has one that will read up to 400 A. for about $50 (http://www.sears.com/craftsman-digital-clamp-on-ammeter/p-03482369000P). If you do a search for digital multimeters, you'll probably find one that can measure resistance in the range you need.
Good luck!
https://www.amazon.com/dp/B0000WU1A2/?tag=pfamazon01-20
I had one of these before, they go up to 20A. They're kind of shitty, and I used my fluke43b for almost all my power stuff. Google the spec sheet, I think the input impedance is a bit lower than what you want. It's greater than 7MΩ though. The price is also really good, however.
Two meters, that are simple to use and cheap to replace if they get damaged, might be a better option than trying to find one that will do everything you want. For example one designed to measure domestic (or industrial) mains power, and another for electronics.
You don't say why you want to measure resistance down to 200 mOhms as compared with just a continuity test, but bear in mind that measuring small resistances accurately is not just a matter of putting a test probe on each end of the resistance. You need to eliminate of compensate for stray resistance (e.g. the meter lead connectors), stray induced EMFs, accidentally creating thermocouples between different materials in the measuring circuit, etc.
if you want to measure small resistances for safety checking on mains-powered equipment (e.g. checking Earth connections etc), you really need a test meter designed for that task.
Ok this is the Meter I would like to get first.
I need to stick the Probes in an House Hold Outlet to Read the Current.
Do they have this type?
Wow. This tells me you should not be messing with this stuff. Also tells me you might not actually know what you need. Measuring current is an operation that involves breaking the circuit and inserting the meter is series. Sticking the probes and an outlet as you describe would be a voltage measurement. Try this with a meter set to measure current and you will likely cause smoke and wreck your meter.
The leads will melt, fuses will blow, I've seen it happen before.
The better alternative to measure current is get a clamp like the one posted above. Clamp yourself onto the plug of the equipment drawing the current you want to measure to take your reading.
Ok if I get a Clap A Meter and put it around say the cord coming from a TV Set going to the Outlet it will give me the Crrent the TV Set is Drawing right?
I want to see the amount of current the Outlet is putting out.
More or less.
The outlet doesn’t put out any current on its own.
You have to clamp it around only ONE conductor in the cord. Clamping around both will measure the current in both wires, which are equal in magnitude but opposite in polarity so they will cancel and give you a net reading of zero.
Well I know an Outlet can Supply 120 Volts at 15 Amps.
And what you plug into the Outlet will Draw what it needs.
I know the Amps is how many Electrons are moving past One Point in one Second.
Now if I want to see how many Volts an Outlet can Supply I can use a VoltMeter.
But a Clamp A Metter will just tell me what the Device pluged into it is Drawing.
How can I see how Many Amps an Outlet can give?
Hi biferi. There is no safe way to measure such a maximum current capability, but fortunately you should never have a need to, anyway. The current rating of every power outlet is predetermined by the physical installation, and is a function of the hardware (household wiring, sockets and switches, and fuses or circuit breakers). The maximum current rating of every outlet is a regional standard and is usually shown on the outlet itself and/or the fusebox. Figures of 10 amps and 15 amps are common. The total current allowed for any particular household installation is also predetermined by the cabling leaving the main switchboard; residents can't simultaneously load all outlets to their rated (maximum) currents and still expect the switchboard circuit breakers won't trip!
If an outlet is suspected of being faulty or is unable to supply its expected rated current, then you must call a properly qualified and licensed electrician to investigate the problem and fix it. There is absolutely nothing you yourself can attempt to do about the fault, in such cases.
Not sure what you are saying here. The first statement implies you do not need the last question answered. Are you saying you want to load test an outlet or circuit? What are you expecting to happen when the circuit can no longer supply the 15 amps? I suspect that you do not fully understand what you are asking. There is NOTHING WRONG WITH THAT as long you accept it and take steps to correct those misunderstandings. I am guessing that with every post made here you have new questions and are more confused. That's ok. We are here to help.
This thread has many similarities to "what is the right kind of bubble bath for me and my toaster".
Please try and impress on the OP that what he intends is a) dangerous, and b) futile, since it doesn't measure what he wants.
I sense that the OP wants to be able to measure something about current and does not truly know how or what.
I got my first multimeter as a young kid and thought if you want to know the voltage of a battery (AA for instance) you set the meter to volts and hook up the probes. Mistakenly, I thought if you want to know current you do the same except set it to current. Glad I never tried it with a car battery. It sounds as if this is the same mentality as the OP. He just doesn't fully grasp voltage and current measurement.
The best way to determine the max current is to go to the fuse (or breaker) box and look at the fuse or breaker rating.
In the scenario you describe, the outlet is putting out precisely the same current as the TV set is drawing¥. There is no need to try to measure it a second way.
¥ assuming the TV is the only device plugged into that particular power socket
In answer to the OP's original question, check out Fluke Meters.
http://en-us.fluke.com/products/clamp-meters/#fbid=Br4DOckeOSz
They are some of the best on the market. You will need a clamp-on for the current levels you quote, but they have a line of clamp-ons that also have all the other multimeter functions.
AceEngineer
And 15 amps at mains voltage is enough to kill you.
OP just stay away from this. You don't have enough background to ask the right questions let alone do measurements.
I suspect you want to measure power consumption from a PC, in which case I would use something like
http://www.lacrossetechnology.net.au/ccdata/images/imageMain_4_32.jpg
I also agree that you must stay away from this stuff op.
Also the max current your outlet can provide depends on two things, wire gauge and the circuit breaker. If the circuit breaker is properly sized, the max current allowed will be below whatever the breaker is rated at.
If the breaker is faulty and does not trip as it should, the max current you can pull is dependant on the gauge of the wire. Basically, the thicker the wire the more current you can pull before the insulation burns out and the circuit shorts.
You also have to consider the insulation, some wires can handle more current than others based on the insulation on the wire.
I work with electricity on the 24v, 120v and 480v 3phase levels so I can answer questions pertaining to those three.
Can anyone help?
Measure the voltage drop across a shunt resistor, the same thing people have been doing since the beginning. That's what the ammeter in your meter is doing anyways.
Current, just like mass flow, is difficult to measure cheaply. Most circuits indirectly measure current by directly measuring voltage drops across know resistances.
1. What is a multimeter and why is it important for PC repair?
A multimeter is a tool used to measure electrical signals, voltage, current, and resistance in electronic devices. It is important for PC repair because it allows technicians to troubleshoot and diagnose issues with a computer's hardware components.
2. What are the essential features to look for in a multimeter for PC repair?
The essential features to look for in a multimeter for PC repair include accuracy, voltage and current ranges, resistance measurement, continuity testing, and diode testing. These features are necessary for accurately diagnosing and repairing PC components.
3. How do I choose the right multimeter for PC repair?
When choosing a multimeter for PC repair, it is important to consider the features mentioned above as well as the brand, durability, and cost. It is also helpful to read reviews and ask for recommendations from other technicians.
4. Can I use a regular multimeter for PC repair?
Yes, you can use a regular multimeter for PC repair. However, it is recommended to use a specialized multimeter for electronics and computers to ensure more accurate readings and avoid potential damage to the device.
5. How often should I calibrate my multimeter for PC repair?
It is recommended to calibrate your multimeter for PC repair at least once a year or whenever you notice a significant difference in readings. Regular calibration ensures accurate measurements and reliable results.
  • General Engineering
  • Electrical Engineering
11K
  • Computing and Technology
  • Aerospace Engineering
