Can Friction Actually Speed Up an Object?
  • Thread starter jchojnac
How much time does it take for the box to reach its final speed?Hint: for (b), use the definition of acceleration :smile:In summary, an object placed on a moving conveyor belt will experience a friction force that speeds it up. The distance the object moves before reaching the final speed can be calculated using the work-energy theorem, and the time it takes to reach the final speed can be found using the definition of acceleration.
jchojnac
39
It is sometimes claimed that friction forces always slow an object down, but this is not true. If you place a box of mass M on a moving horizontal conveyor belt, the friction force of the belt acting on the bottom of the box speeds up the box. At first there is some slipping, until the speed of the box catches up to the speed v of the belt. The coefficient of friction between box and belt is . Do not worry about italics. For example, if a variable g is used in the question, just type g and for use mu.
(a) What is the distance d (relative to the floor) that the box moves before reaching the final speed v? (Use energy arguments to find this answer.)
(b) How much time does it take for the box to reach its final speed?
W=-Fd/2
K=1/2mv^2
f=mu*N
Can't figure it out.
Welcome to PF!
Hi jchojnac! Welcome to PF! :smile:
(have a mu: µ :wink:)
jchojnac said:
If you place a box of mass M on a moving horizontal conveyor belt, the friction force of the belt acting on the bottom of the box speeds up the box. At first there is some slipping, until the speed of the box catches up to the speed v of the belt. The coefficient of friction between box and belt is … mu.
Hint: for (a), use the work-energy theorem:
work done by friction = energy gained :smile:
I would like to clarify that the statement "friction forces always slow an object down" is not entirely accurate. While friction does often act to slow down an object, it is not always the case. In certain situations, like the one described in the problem, friction can actually speed up an object.
To solve for the distance d, we can use the principle of conservation of energy. Initially, the box has no kinetic energy and all the work done on it by the friction force is converted into potential energy. As the box speeds up, the potential energy is converted into kinetic energy. Therefore, we can equate the work done by the friction force with the change in kinetic energy:
W = Kf - Ki
Where W is the work done by the friction force, Kf is the final kinetic energy, and Ki is the initial kinetic energy (which is zero).
We can also express work done by the friction force as the product of the friction force and the distance d:
W = f*d
Substituting this into our equation, we get:
f*d = Kf - Ki
Since f = mu*N, we can rewrite this as:
mu*N*d = 1/2*M*v^2
We know that N = Mg, so we can further simplify to:
mu*M*g*d = 1/2*M*v^2
Canceling out the mass and rearranging, we get:
d = v^2 / (2*mu*g)
This is the distance that the box moves before reaching the final speed v.
To solve for the time it takes for the box to reach its final speed, we can use the equation for average velocity:
v = d/t
Substituting in our previously calculated value for d, we get:
v = (v^2 / (2*mu*g))/t
Solving for t, we get:
t = 2*mu*g/v
This is the time it takes for the box to reach its final speed v.
1. What is a multiparticle system?
A multiparticle system is a physical system composed of many particles, such as atoms, molecules, or subatomic particles, that interact with each other through various forces.
2. How do you describe the behavior of a multiparticle system?
The behavior of a multiparticle system can be described using statistical mechanics, which uses mathematical models to predict the collective behavior of the particles based on their individual properties and interactions.
3. What are some examples of multiparticle systems?
Some examples of multiparticle systems include gases, liquids, solids, plasmas, and even the entire universe, which can be considered a multiparticle system of galaxies and celestial bodies.
4. What are the challenges in studying multiparticle systems?
One of the main challenges in studying multiparticle systems is the large number of particles involved, making it difficult to track and analyze each individual particle's behavior. Another challenge is the complexity of the interactions between particles, which may require advanced mathematical techniques to understand.
5. How are multiparticle systems relevant in different fields of science?
Multiparticle systems are relevant in various fields of science, such as physics, chemistry, biology, and materials science. They help us understand the behavior of matter at different scales, from subatomic particles to the entire universe, and have practical applications in fields such as engineering, medicine, and technology.
