Multiple client connections
  1. Feb 3, 2013 #1
    Hi,
    I have a simple tcp server, to which i would like to add support for multiple client connections via pthreads. This is what i had in mind, calling accept in a separate thread.
    I this similar to what you would do?
    Code (Text):
    int sock = socket(PF_INET,SOCK_STREAM,0);
    int sock_fd[10];
    struct sockaddr_in client_addr[10];
    int size = sizeof(&client_addr);
    void *Thread1(void *arg){
       for(i=0;i<9;i++){
      sock_fd[i] = accept(sock,(struct sockaddr *)&client_addr[i],size);
  3. Feb 7, 2013 #2
    No.
    Normally accept is blocking until new incoming connection.
    So, simplest way would be like this:
    Code (Text):
    void* ConnectionThread(void* pv)
        int fd=(int)pv;
        close(fd);
        return 0;
    void main_loop(unsigned short port)
        struct sockaddr_in loacal_addr;
        local_addr.sin_family=AF_INET;
        local_addr.sin_port=((port>>8)|(port<<8));
        local_addr.sin_addr.s_addr=INADDR_ANY;
        int lfd=socket(AF_INET,SOCK_STREAM,0);
        if(0!=bind(lfd,(struct sockaddr*)&local_addr,sizeof(local_addr)){
            perror("bind");
        listen(lfd,5);
        while(true){
            struct sockaddr_in remote_addr;
            socklen_t slen=sizeof(remote_addr);
            int afd=accept(lfd,(struct sockaddr*)&remote_addr,&slen);
            if(afd==-1){
                perror("accept");
            }else{
                if(0!=pthread_create(0,0,ConnectionThread,(void*)afd)){
                    close(afd);
    Also there is an option of using asynchronous non-blocking operations instead of/ or in mix with multithreading
Loading...
Similar Threads for Multiple client connections
Is there such a thing as multiple simulation?
