Hooke's Law & Multiple Springs: Clarification Needed
In summary, Hooke's law can still be applied to particles joined to multiple springs, but now the total length of the springs is constrained. The forces on each particle from the springs can be compressive or tensile, depending on their initial state. When analyzing a problem, assume all springs are in compression or extension and then determine the new forces on the particles from the changes in spring length. The direction of the forces does not matter, as they can simply be assumed to point in the opposite direction if needed.
ElDavidas
80
How do you apply Hooke's law to particles joined to multiple springs. For example in the diagram below:
0rigin |-\/\/\/\/- P1 - /\/\/\/\- P2 -/\/\/\/\/\/-|
I mean, would you have to introduce a new variable to indicate displacement if you altered one of the springs?
Also, suppose the left spring is compressed, does this mean that the middle and right hand springs are extended? So the tension is -ve for spring one and positive for springs two and three?
I would appreciate if someone clarified this for me as it would better my understanding. This type of question seems to come up quite frequently.
Hooke's law works the same way as always, but now the total length of the three springs is constrained.
That could certainly be true. It depends on how the springs are stretched/compressed compared to their unstretched lengths. But, assuming that the two end points (|) are fixed, the total length is also fixed.
Perhaps things will be clearer if you worked through a particular problem.
I'm not sure what you mean by altering one of the springs.
But you should analyse each particle individually.
P1 had forces T1 and T2 from springs S1 and S2 acting on it.
Similarly, P2 has forces T2 and T3 acting on it from springs S2 and S3.
T1, T2 and T3 are compressive or tensile forces depending upon whether the spring(s) are in compression or extension.
When beginning the analysis, assume all springs are in compression (or in extension, if you are told otherwise).
Let each particle be displaced by a small amount in the +ve direction. Assume the springs are still in compression (or extension, if that was your initial assumption).
Now you can figure out the new forces acting on the particles due to the new extension and/or compression of the various springs.
The assumption of (force) direction doesn't really matter too much. Since if you assumed one direction for a force and it worked out to have a -ve value, then that simply means that it should point in the opposite direction to that assumed.
What is Hooke's Law?
Hooke's Law is a fundamental principle in physics that states that the force needed to extend or compress a spring by some distance is directly proportional to that distance.
How does Hooke's Law apply to multiple springs?
In the case of multiple springs connected end-to-end, the overall force acting on the system is equal to the sum of the individual forces acting on each spring. This is known as the principle of superposition.
Can Hooke's Law be applied to non-ideal springs?
Yes, Hooke's Law can be applied to non-ideal springs as long as the spring remains within its elastic limit and follows a linear relationship between force and displacement.
What is the equation for Hooke's Law?
The equation for Hooke's Law is F = -kx, where F is the applied force, k is the spring constant, and x is the displacement of the spring from its equilibrium position.
How is the spring constant determined for multiple springs?
The spring constant for multiple springs is determined by taking the reciprocal of the sum of the reciprocals of each individual spring's constant. For example, if two springs with constants k1 and k2 are connected end-to-end, the overall spring constant would be 1/(1/k1 + 1/k2).
