Understanding the Multiplicity of Poles in Complex Analysis
In summary, the multiplicity of a pole in complex analysis refers to the order or power of the term with the largest negative power in the Laurent series of a function. This can be extended beyond polynomials to meromorphic functions, which have poles as non-holomorphic points. An isolated singularity is a pole with infinite multiplicity, and more generally, a function has a pole at a point if the limit of (z-a)^n times the function exists, but the limit of (z-a)^(n-1) times the function does not.
Icosahedron
54
In complex analysis, what is understood by the multiplicity of a pole?
thank you
Mathematics news on Phys.org
For [tex]f(z)=\frac{1}{(z-z_0)^n}[/tex], the pole at [tex]z=z_0[/tex] has multiplicity n
i.e. the order of the pole of f at z, equals the multiplicity of the zero of 1/f, at z.
May this be extended beyond polynomials?
thanks!
it makes sense for the quotient of two holomorphic power series, yielding what is called a laurent series, i.e., a series with at most a finite number of terms of negative powers.
on any open set, the fraction field of the holomorphic functions form what is called the field of meromorphic functions on that set. those have at worst poles as non holomorphic points.
e^(1/z) has a worse than pole point at z = 0. isolated non holomorphic points are called (isolated) singularities. the simplest actual singularities of functions defined by power series, possibly infinite in both directions, i.e. summed over all integer powers of z, are the poles.
I.e. the multiplicity is the power of the term with the largest negative power in the laurent series of the function?
Does this also mean that an isolated/(essential?) singularity is a pole with infinite multiplicity?
More generally, a function f(z) has a pole at z= a of multiplicity n if and only if
[itex]\lim_{z\rightarrow a} (z-a)^nf(z)[/itex] exists but [itex]\lim_{z\rightarrow a} (z-a)^{n-1}f(z)[/itex] does not.
That definition put everything in place, thanks!
What is the multiplicity of a pole?
The multiplicity of a pole is a concept in mathematics that describes the number of times a particular value appears as a root of a polynomial function.
How is the multiplicity of a pole determined?
The multiplicity of a pole is determined by examining the behavior of a polynomial function near a particular point. If the function approaches the point with a slope of zero, then the point is a root with a multiplicity of at least one. The multiplicity increases by one for each time the function returns to the same point with a slope of zero.
What does the multiplicity of a pole tell us about the function?
The multiplicity of a pole provides information about the behavior of a polynomial function near a particular point. It can indicate whether the function crosses or touches the x-axis at that point, and how many times it does so. This information can be useful in graphing and analyzing the function.
Can the multiplicity of a pole be any number?
No, the multiplicity of a pole must be a positive integer. This is because the concept of multiplicity is based on the repeated zero of a polynomial function, and non-integer values do not have a repeated zero.
How is the multiplicity of a pole related to the degree of a polynomial function?
The multiplicity of a pole is related to the degree of a polynomial function by the Fundamental Theorem of Algebra, which states that a polynomial of degree n has exactly n complex roots (counting multiplicities). This means that the sum of the multiplicities of all the poles of a polynomial function will always equal its degree.
  • Differential Equations
