Music/physics questions
  • Thread starter physics_06er
In summary, the conversation involves a series of questions about physics concepts, including standing waves in open tubes, the role of resonances in string instruments, and calculating sound levels and reverberation time. The conversation also includes discussions about the formulas and calculations involved in these concepts. The conversation ends with a question about calculating the absorption coefficient for walls in a circular room.
physics_06er
25
Hi could someone please tell me if I have answered these correctly?
1)-Explain how traveling waves can be formed by traveling waves, and hence how the freq's. of a standing waves in an open tube are related to the speed at which sound travels along the tube?
travelling waves formed when to waves traveling in opposite directions with same freq. and amplitude cancel each other out. frequencies of standing waves in open tubes are related to speed by their wavelength. As one whole wavelength is 4 times the length of the tube-we must change the length of tube for different speeds to occur...is something like ok?
2)-in string instruments, unlike most wind instruments, resonances of the body of the instrument play no part in determining pitch. what role do these resonances play in a string instrument, and how is it desirable for them in be distrubuted in freq.?
they amplify sound right?...hmm what else :redface:
3)sound level produced by flut is 53dB
a)what pressure amp. is this...can i justuse formula Lp=20log(P/Po) where Lp=53 and Po=2x10^-5
Last one-this is from textbook solution but am unsure why thye do a certain step..
3)Calculate reverberation time for a room 20m x 15m and 8m high..I get all the steps except they when they calculate the area of wall they go..
A=(2x15x8+2x20x8)...why?
Thanks very much
physics_06er
1)-Explain how <travelling> standing waves can be formed by traveling waves, and hence how the freq's. of a standing waves in an open tube are related to the speed at which sound travels along the tube?
<travelling> standing waves formed when to waves traveling in opposite directions with same freq. and amplitude cancel each other out. frequencies of standing waves in open tubes are related to speed by their wavelength. As one whole wavelength is 4 times the length of the tube-we must change the length of tube for different speeds to occur...is something like ok?
Thanks very much
physics_06er
For #1 you must mean standing waves. You realize that interference is involved, but you make it sound like the two tracelling waves anihilate one another. They do not. A standing wave results because at any given position, the phase relationship between the two waves is constant. At some points the two waves are always exactly out of phase, while at other points the two waves are always exactly in phase. This creates the nodes and anti-nodes. At points in between there is a gradual change in the phase and a gradual change in the amplitude of the motion or sound pressure at a fixed point.
The length and diameter of a tube have no significant effect on the speed of sound. Speed is the one constant in the situation. Changing the length of the tube changes the resonant frequency of the tube because the open end of the tube is very close to an antinode while the closed end is a node. The tube length controls the wavelength of the resonant wave, and the wavelength determines the frequency.
http://hyperphysics.phy-astr.gsu.edu/hbase/waves/clocol.html#c1
For #2, I suggest you look here
http://hyperphysics.phy-astr.gsu.edu/hbase/music/viores.html#c3
This is one example of the resonance of a stringed instrument. It should help you elaborate on your conclusion.
#3 looks good if you have the right number for the reference pressure
#4 There are 4 walls of the same height (8), and two widths (15 and 20), typical of a rectangular room. A is the total surface area of the 4 walls. There are only two different size walls, so they multiply the area of each size by 2 and add.
and if a room had a circular floor area eg: 1285m^2
(approx radius 20m) and ceiling height 15m??--would would the calculation there be??
Thanks in advance
physics_06er
Thanks in advance
physics_06er
If you are looking for the surface area of the walls, think about unwrapping the cylinder wall and laying it flat. What would it look like? What would the dimensions be?
Hi
can u please see if i have the calculations right-
room has circular floor area of 1285m^2 (radius approx. 20m) height=15m the floor is wooden, walls/ceiling mainly plastered and but quarter of wall covered by hearvy drapery
i have ti estimate reverberation time at 2000Hz
absorption coefficients at 2000Hz
plaster on lath=0.04
wood floor=0.06
draper, heavyweight 0.70
First I have to calculate absorption of each surface using A=Sa (S=area a=coeffecient)-then-T60=0.161*V/A
so calculating volume of room first=1285x15=19275m^3 (areaxheight right?)
then A(Floor)=1285x0.06 (as alrady given floor area)
A(ceiling)=1285x0.04 (ceiling also circular-hence area given)
A(walls)=hmm this is the calculation I am unsrue about-after I work out this part all I do is add up A's and use the reverberation forumla aye?
but can you please explain the A(wall) does it have something to do with 'pi'
physics_06er said:
Hi
wood floor=0.06
The area of a circle is S=pi*r^2 (using S for area as you have done). Using the given area of 1285m^2 you can calculate the radius to find r = 20.22m, so the given information of the radius being about 20m is consistent. The circumference of a circle is c=pi*d or c=2*pi*r. The area of the walls is the circumference times the height of the wall, S=c*h=2*pi*r*h . If it is not clear to you why the area is the circumference times the height, imagine papering the wall with strips running horizontally around the room. Each strip would have to go all the way around the room, or one circumference. If you had a strip 15m wide and as long as the circumference of the room, it would perfectly cover the wall. If you laid that strip out flat, it would be a rectangle with dimension c by h, having area S=c*h
1. How does sound travel through different mediums?
Sound is a type of wave that requires a medium, such as air, water, or solids, to travel. When an object vibrates, it creates sound waves that travel through the medium by causing the particles in the medium to vibrate. The speed of sound depends on the properties of the medium, such as density and elasticity. For example, sound travels faster through solids than through liquids or gases.
2. What is the relationship between frequency and pitch?
Frequency is the number of vibrations or cycles per second, measured in Hertz (Hz). Pitch is how high or low a sound is perceived, and it is directly related to frequency. The higher the frequency, the higher the pitch. This means that as the frequency of a sound wave increases, the pitch also increases.
3. How do different musical instruments produce different sounds?
Each musical instrument produces a unique sound due to the different ways in which they create vibrations and manipulate sound waves. For example, string instruments produce sound by plucking or bowing strings, while wind instruments create sound by blowing air through a tube. The shape and size of the instrument also play a role in the quality and timbre of the sound produced.
4. What is the Doppler effect and how does it relate to music?
The Doppler effect is the change in frequency of a sound wave as the source of the sound moves relative to the observer. This results in a perceived change in pitch. In music, the Doppler effect can be heard when a vehicle with a siren passes by, causing the pitch of the siren to change as it moves towards and away from the listener.
5. How does music affect the brain?
Studies have shown that listening to music can have a variety of effects on the brain, including improving mood, reducing stress and anxiety, and increasing cognitive function. Music can also activate different regions of the brain, such as the auditory cortex, motor cortex, and limbic system, which are responsible for processing sound, movement, and emotions. Additionally, playing a musical instrument can also have a positive impact on brain development and function.
  • Materials and Chemical Engineering
  • Classical Physics
