- #141
Fra
- 4,105
- 607
i'm probalby doing a mistake by adding this but...
We attack this differently but I think I see Vanesch point here. I am not quite prepared to present my view consistently yet (I'm working on it) but my information theoretic ideas to explain the connection between statistical (impure) mixtures and pure mixtures depends on how we define "addition of information".
I technically see different measurements, belonging to different probability spaces. And the exact relation between the spaces is needed to define addition of information.
Since normally conditional probabilities is defined like
[tex]
P(A|B) := \frac{P(A \cap B)}{P(B)}
[/tex]
The question is what P(A|B) supposedly means unless they belong to the same event space?
This is IMO a _part_ key to explain the reason for different ways to "add information". And when we are dealing with systems of related "probability spaces" in between which we make transformations, then it does matter in which space we make the addition. This is something that isn't analysed to satisfaction normally. Normally the defining relation between momentum and position are postulated, one way or the other. This postulates away something I personally think there is a better explanation to.
I think there is a way to grow a new space based on the uncertainty in the existing one. New relations are defined in terms of patterns in the deviations of existing relations, and relations are "selected" as per a mechanics similar to natural selection. The selected relations implements an efficient encoding and retains a maxium amount of information about the environment in the observer.
The limit is determined by the observers information capacity, and beyond that the only further "progress" that can be made is for the observer/system to try to increase it's mass. Here I expect a deep connection to gravity.
Constraining the information capacity is also I think the key to staying away from infinities and generally divergent calculations. There will be a "natural cutoff" due to the observers limited information capacity.
I'm sorry if this makes no sense, but I hope that given more time I'll be able to put the pieces together, and it's designed to be all in the spirit of a minimum speculation information reasoning that I personally consider to be the most natural extension to the minimalist interpretation.
/Fredrik
vanesch said:you do not get out the same results than when you keep the electron wavefunction as a wavefunction and not a statistical mixture of positions.
[tex]
[/tex]
/Fredrik
