My lecturer says "Special relativity is absolutely wrong"
In summary: However, as far as I know, there has never been an experiment that has found such massive particles.TL;DR - My lecturer is saying that FTL particles violate SR because they would travel faster than the speed of light in a given coordinate system, but there has never been an experiment that has found particles that fast.
  • #71
PeterDonis said:
But such "explanations" are heuristic at best, and outright misleading at worst. Only the math gives an explanation that is precise enough to not be heuristic and not be misleading. So if you don't speak math, you have to accept the fact that the explanations you can follow will not be that precise.
Yes, but it can't just be mathematics. It has to include a description or interpretation of the objects (forces, fields, particles etc.) that the mathematics embodies so that they can be linked to the world they intend to describe and so they can be experimentally tested. I suspect it is the difference use of some of these terms in normal usage and in specific scientific usage that can lead to misunderstandings. Unfortunately, I think, that sometimes this is deliberately done for effect.
This was brought home to me when my daughter studied economics at university. The equations she was using were the same as the ones I had encountered in classical mechanics. The mathematics was the same but the subject matter was very different.
Regards Andrew
  • #72
I would say it has to include a description of which mathematical quantities correspond to direct observables, and how those observables are measured. Adding a description of the "objects" is not, strictly speaking, necessary, although it is practically always done; and descriptions in terms of "objects" are not necessarily precise, since the same words are often used to describe different mathematical quantities, or the same quantities are described using different words.
Yes, and this is a key reason why the scientist's answer to questions about what a word means will ultimately be "look at the math". The math is unambiguous, whereas ordinary language is not.
Likes gjonesy
  • #73
That may well be strictly correct but would leave a very sterile physics as so few "objects" are directly observable. No electrons, protons, Higgs. Unless I have misunderstood you.
Regards Andrew
  • #74
In physics we can never say anything is "absolutely right". There could always be an experiment that we haven't thought of that could prove that the theory is wrong, or at least incomplete. Of course Einstein understood that Special Relativity was incomplete, but does that make it wrong? Very few theories can be said to be complete. Almost every theory will break down at some scale. We aren't even sure that General Relativity applies at the quantum scale, but probably not. Does that mean that almost every theory in physics is wrong? That's an extreme position to take. So then, what is "absolutely wrong"? Absolutely wrong would mean that a theory would not predict results that could be verified by experiment over any reasonable range of application. Given that definition, I'd have to say your lecturer is "absolutely wrong". Of course, there is nothing to be gained by making that point to her/him. If the grade is important enough, say the difference between getting the degree or not, I'd present my case to the head of the Department. Otherwise, I'd just let it go and move on.
  • #75
That can't be right as maths without context is just "maths" it must include some connection to the world - observables, objects
Do the equations describe a spaceship in flight or the stock exchange?
Regards Andrew
  • #76
Ben Niehoff said:
Only Sith deal in absolutes.
Definitely a Sith Lord!:shady: In disguise
Likes Battlemage!
  • #77
The math certainly has quantities in it which can be labeled as "electrons", "protons", "Higgs particles", etc. But those quantities (for the most part) are not direct observables. Describing those quantities as "electrons", "protons", "Higgs", etc. is not necessary to predicting the values of the direct observables, which are what we actually compare with experiments; we do it because it helps us conceptualize what is going on, not because it is necessary to the model.
This also ties into the other issue you raised, about words having different meanings to scientists and non-scientists. When a non-scientist hears the word "electron", he probably thinks of a tiny little billiard ball zipping around. But the scientist actually means a quantity in the mathematical model--in our most fundamental current model, it's a quantum field. This mathematical quantity does not correspond to anything in an ordinary person's intuition, so calling it an "object" is already a stretch, and there is no other ordinary language word that captures it any better. So the best a scientist can do is to emphasize that all of the ordinary language descriptions are at best heuristic, and that the only precise description is the math. That's not "sterile" physics; it's precise physics. The fundamental quantities in our models are unlike anything in your ordinary experience, so physicists should not use language that suggests that they are--and there is no ordinary language that doesn't.
What actual observations do the direct observables in the mathematical model correspond to? If they correspond to the position, velocity, acceleration, mass, etc. of a space ship, then the equations are describing a space ship. If they correspond to stock prices, price changes, etc., then the equations are describing the stock exchange.
My point is that the link between scientific models and reality is not in the names we give to internal objects in the models; it is in the correspondence between the direct observables in the models and our actual observations. You can give names to internal objects all you want, but if you don't know what the direct observables correspond to, you don't know if your names for the internal objects are the right ones.
  • #78
DrSuage said:
His little schpiel about General Relativity allowing faster than light travel is absolute hokum.
Special Relativity is not wrong in the way that Newtonian mechanics is not wrong. They are just approximate theories - effective only within their domain of application.
GR doesn't allow FTL travel per se. It does, in principle, allow travel that effectively gets one between two points FTL to an outside observer but it requires exotic matter. This is the so-called Alcubierre drive.
  • #79
You call it precise but to my mind it is also sterile. In your world the Higgs bosson and Gavitational waves were not discovered but just some aspects of the internals of the mathematical machinery of the Standard model of Particle Physics and General Relativity were confirmed. That maybe sufficient motivation to professional Physicists but I doubt it would attracted much funding or public interest.
We will have to agree to disagree on this.
Regards Andrew
  • #80
PeterDonis said:
I disagree.
About what?
Physicists are supposed to study the implications and weaknesses and overall purpose of theories--that's pretty much the main purpose of peer review.
Ok, that means you think they are supposed to learn philosophy of science. That is what makes possible to critically assess how the math symbols are best interpreted. The most usual alternative is just swallow others' philosophies without even realizing it.
  • #81
When I was at Columbia, we had a Physics and Philosophy course taught by the guy who appeared on "What the Bleep do we Know?". It was my understanding from other students that the quantum mechanics professor didn't have the highest opinion of his interpretation of QM. Ergo, as Russ says, go speak with another professor if you have one, who knows more about the topic.
Nevertheless, remember the golden rule of academia: the guy grading your papers is always right, especially when they are wrong.
  • #82
There is one thing I know about the mind, a picture is worth a thousand words, a value and vector a quantity, numbers and symbols on a black board or sheet of paper or computer screen. All of these "things" paint a picture in the mind of the physicist. You can look at every equation and data point for the double slit but is it only the numbers you see? Or do you see the filters the detectors the screen the wave like pattern formed? Do you visualize? Do you conceptualize? How would you create a real world experiment, with just numbers? The particle accelerator at CERN LHC isn't constructed of numbers and equations...its made of metal. There has to be a picture beyond the equations...there has to be real vision IMHO.
  • #83
No, in my world observations were made that matched the predictions for particular direct observables in the Standard Model of particle physics and General Relativity, and those things can be described, in ordinary language, as "discovering the Higgs boson" and "observing gravitational waves". But the meaning I give to those ordinary language descriptions might be different from the meaning you give to them.
The question is: are you comfortable with knowing that you only have a heuristic, approximate, possibly misleading understanding of what those terms actually mean? If your answer is yes, then we have no disagreement.
Same question here: are you comfortable with knowing that your interest in, and willingness to fund, basic research in physics is based on a heuristic, approximate, and possibly misleading understanding of what the physicists are doing? If your answer is yes, then we have no disagreement.
Btw, plenty of physicists would apparently answer "yes" to this as well, since they spend considerable time giving heuristic, approximate, possibly misleading descriptions in ordinary language of what they are doing, for the express purpose of stimulating public interest and obtaining funding.
  • #84
No, it means that I draw the boundary between "science" and "philosophy of science" differently than you do.
  • #85
Strange as it may seem to you I do my best to understand many areas of Physics. I study the recommended texts, linked articles and follow the discussions on this forum as best as I can. I have to accept that given my age and abilities this quest will never be fully realized. So no I am not comfortable with a heuristic, approximate, possibly misleading understanding. I continue to strive to improve it.
Regards Andrew
  • #86
It doesn't seem strange to me at all. I'm simply trying to get clear about your position.
Then you should not be comfortable with descriptions like "the Higgs boson was discovered" or "gravitational waves were detected" by themselves; you should want to understand the math beneath them (and you say you do), which will tell you things that are very different from the ordinary language meanings of those phrases, and certainly are not conveyed by those phrases. Which means that, by your own stated preference, it is the ordinary language phrases that are "sterile", since they don't give you all the much richer underlying meaning that is contained in the math.
  • #87
I don't go along with this business of 'ordinary language' being sterile whereas math has some 'rich underlying meaning'.
In reality, what that means is that physicists don't have a sufficiently eloquent grasp of language to enable them to translate their mathematical symbols into the appropriate and corresponding terminology. Which is not surprising as it's difficult to wield expertise in two disparate subjects.
At the end of the day every mathematical concept can be expressed linguistically, but not vice versa.
Likes RockyMarciano and andrew s 1905
  • #88
Science needs philosophers of science like birds need ornithologists.
Likes CalcNerd, vanhees71, phinds and 4 others
  • #89
No, what it means is that the words that are used to refer to concepts in our scientific theories can't have their intended meanings to someone who does not understand those concepts. And ultimately the only way to be sure someone understands those concepts is to look at the math.
To put it another way: the meanings of words in ordinary language ultimately depend on ostensive definitions. If you want to know what a "cat" is, ultimately you have to get directly acquainted with some cats. But when you're talking about abstract concepts, the analogue of getting directly acquainted with cats is getting acquainted with those concepts, which can only be done by abstract thought. Sometimes concrete models can be used to help--for example, in learning set theory we can use concrete sets of things to illustrate the axioms and theorems. But nobody has a concrete model that works exactly like the quantum fields describing the fundamental particles in the Standard Model. So the only way to get acquainted with those concepts is to look at the math. Words can't help unless you have the mathematical concepts already in your head for the words to refer to.
  • #90
:oldlaugh:
Likes gjonesy
  • #91
The simple version of the situation is: Nothing can travel faster than c, but under certain circumstances the distance between two points can increase faster than c. (At first glance they might sound like the same thing, but they are not.)
  • #92
Correct observation. Note that this is as true in SR as in GR. Consider the simple case of an inertial frame in SR, with object A moving to the left at .9999...c and B moving to the right at .999...c. Then the distance between them grows by 1.9999...c [despite their relative velocity being <c]. Using a flat space analog of cosmological coordinates, you can get a separation speed between inertially moving bodies of any multiple of c. Note, this distance is integrated proper distance so it is not a matter of coordinate units. It is instead, a matter of how flat spacetime is foliated by the coordinates. In particular, each spatial slice being hyperbolic in geometry is what allows this result.
Likes gjonesy
  • #93
I don't see how. SR states that nothing can travel faster than c, no matter what. It doesn't matter what the relative velocities are between the observer and the object, when the observer measures the velocity of the object, it will always be under c.
The reason why under certain circumstances the distance between two points can genuinely grow faster than c is because of non-linear spacetime geometry, a concept that only GR introduced.
I don't think that's how SR works at all. You can't just sum velocities like that.
  • #94
Wrong. While the velocity of A relative to B, measured by B, or vice versa, is < c, the growth rate of separation between A and B can approach arbitrarily close to 2c in a given inertial frame. This is exactly why comparing separation rate to relative velocity is a category error, like comparing temperature to energy.
Warp said:
I
This is false. I made my observation because a surprising number of cosmology presentations make this error. If you take the limit of FLRW solutions to a massless universe, you end up with flat spacetime (i.e. pure SR) in Milne coordinates. These foliate the flat spacetime with hyperbolic spatial slices. The growth of proper distance (along these hyperbolic spatial slices) between inertial world lines that are part of the homogeneous congruence of the solution can by any multiple of c whatsoever (if they are far enough apart). Yet, this is pure SR minkowski spacetime.
Warp said:
I
The velocity addition formula applies to relative velocities. Separation rate (= recession rate) is a completely different category, that is just as unbounded in SR as it is in GR. I highlight this because of the large number of false statements in this regard by cosmologists making a category error. Note that Sean Carroll who has written a great GR text as well as being a notable cosmologist, has written on this point, and does not make this mistake.
  • #95
PAllen said:
This is false.
So what you are effectively saying is that the size of the universe is exactly the size of the observable universe, because the metric expansion of the universe cannot make distances between galaxies grow faster than c. After all, the claim that changes in the geometry of spacetime can cause distances to grow faster than c is "false".
Also ergospheres around rotating black holes do not exist, because the concept is "false".
You learn something new every day.
  • #96
No, you completely misunderstand (charitably; uncharitably, you deliberately and sarcastically distort) what I wrote. I wrote that distance between between inertial bodies can grow faster than c in both flat spacetime and curved spacetime, depending on the foliation. You state this somehow implies that distance cannot grow faster than c. This is the opposite of my claim - that distance can grow faster than c in either SR or GR.
  • #97
PAllen said:
No, you completely misunderstand (charitably; uncharitably, you deliberately distort) what I wrote. I wrote that distance between between inertial bodies can grow faster than c in both flat spacetime and curved spacetime, depending on the foliation. You state this somehow implies that distance cannot grow faster than c. This is the opposite of my claim - that distance can grow faster than c in either SR or GR.
I think there is a fundamental misunderstanding in all of this.
If I'm an observer and am measuring a (massive) object receding from me, according to SR I will never, ever measure said object to be receding from me faster than c, or even at c. It may approach c, and thus may red-shift to almost invisibility, but it will never reach c, and thus never become completely invisible.
However, according to GR the receding object can recede from me faster than c. It thus becomes completely unobservable from my perspective, effectively being beyond an observability horizon. And there is effectively no limit to how much faster than c it can recede. SR does not have this concept because it considers space to be linear and static.
  • #98
@Warp - you are depending on a particular simultaneity criterion (a flat foliation of flat spacetime) to make your statements. @PAllen is using a different, but still perfectly reasonable, simultaneity criterion (a curved foliation of flat spacetime). He's applying GR tools to SR, but he's still talking SR.
If I understand right, you can visualise spacetime as a block. You are slicing it into flat planes and calling each plane "the universe at time t". He's slicing the block into a stack of bowls and calling each bowl "the universe at time t". Spacetime is still the same 3d block, whichever way you slice it, but your definition of space is different so your definition of speed through space is different.
Likes PeterDonis
  • #99
Warp, you are confusing yourself. Shine light to the right and to the left. Each beam travels at speed c. What is the velocity (rate of change) of the separation of the fronts of the two beams? Let's calculate. After 1s, the right beam will be 300000km to your right, the left that much to your left. So the distance between the two has changed from 0 to 600000 in 1s, thus the speed is 2c.
  • #100
Even if you expressed an abstract mathematical concept linguistically, it could still be far beyond the ability for someone not mathematically inclined to grasp. They could recognize where the nouns and verbs are, but the idea being communicated in the words could still be inaccessible to them.
In fact, writing abstract mathematical ideas in words rather than math symbols would very likely make the concepts harder to understand, not easier.
Regardless, words won't help someone understand a concept they are unprepared to understand. This can be readily seen in the definition of a limit. When you PRECISELY describe it in words, using the epsilon-delta definition, the idea can be very difficult to grasp for someone not familiar with that sort of thing. But simply saying "some value this function approaches" is extremely imprecise. And then when you start making more abstract definitions that depend on previous ones things would get very confusing if written in everyday words. Regardless of the way they are written, if you don't have a good understanding of mathematics you aren't likely to grasp what you read.
Likes gjonesy
  • #101
Funnily enough, you might not not fully acknowledge that your meta-comment is pure philosophy of science.:rolleyes:
Whether it s good or bad philosophy is a judgement that can be left to the reader.
  • #102
Equally one could understand the mathematics perfectly and have no clue as to the physical implications or completely misunderstand them. I think we should accept there is a continuum from a full understanding of a physical theory through a more or less hazy understanding to complete ignorance. This will span physicists and non physicists alike.
Regards Andrew
  • #103
Let me try again to get across what your category error is.
In SR, if I measure the speed of an object relative to me, it will always be less than c. However, if I measure the rate of growth of proper distance between between two objects, the result can be up to 2c in an inertial frame, and any value in a non-inertial coordinates (even though I ams still talking about growth of proper distance with respect to proper time of a fiducial observer). The flat space analog of cosmological coordinates is a non-inertial frame (known as Milne coordinates). Note that these coordinates have a cosmological horizon (and do not completely cover all of Minkowsi space). Also, note that as simple as case as a uniformly accelerating observer in SR sees a Rindler horizon form behind them, and objects beyond it become causally disconnected from them. Infinite redshift occurs as an object approaches said horizon, and there is no signal, let alone redshift possible for an object beyond the Rindler horizon.
In going to GR, we have to look more at what relative velocity means. In SR you can define it either as speed in a global inertial frame in which one of the objects is at rest. Or you can define it in terms of 4-vector comparison (dot product of two 4-velocities gives gamma of their relative speed), relying on the fact that parallel transport in SR is path independent, thus distant vectors can be unambiguously compared. Note that it is only relative velocity in one of these senses that is limited to c in SR, as noted above. Unfortunately, in GR, neither of these definitions work at all. Globally inertial frames do not exist; parallel transport is path dependent so there is no such thing as comparison of distant vectors. As a result, relative velocity does not exist in GR except locally (where you can use a local inertial frame; equivalently, vectors at the same event can be compared unambiguously because parallel transport is not necessary). Of course, this local relative velocity in GR is always < c.
Globally, in GR, all you have are analogs of the coordinate dependent quantities described above, that are not limited to c in SR. These things (including recession rate) do not correspond to SR relative velocity at all. There is a limited statement you can make globally in GR that is in the same category as SR relative velocity. That is: while the relative speed of distant objects is inherently ambiguous because of path dependence of parallel transport, no matter what path you use for parallel transport, the result of parallel transport followed by vector comparison is always < c, with no exceptions. Thus there is no way to choose a specific value, but the range of admissable values are all < c.
  • #104
I totally agree in some cases that would be absolutely 110% true, in others there is a gray area, some of the common language used to describe SR and GR have slightly different meanings then they ordinarily would have. In certain cases where someone is making an genuine effort to learn (some of the) concepts and you have a patient teacher who can get those meaning across linguistically by making clear that "common language" isn't adequate and by saying "this" I actually mean "that" you can actually learn (some of the) the concept. I have learned certain things about physics and I "know" it I just can not express it to others the same way because I lack the expertise to translate what I know.. BUT the ones who have taken the time and went over things with me and who have been patient do have this gift of translating (some of the) material. Not all of it can be expressed this way and I will probably never have a full understanding of it and I fully accept it. But the parts that I have been able to grasp are like pearls of wisdom. And that is what's so great about this forum, you have people here who can do that.
  • #105
Closed pending moderation.
Edit: this thread will remain closed, please refer to the forum rules
  • Quantum Physics
