Analysis of Experimental Errors on Wavelength and Angle Measurements
In summary: Now we can find values for other angles that correspond to this equation.It would be helpful to explain why you want to find these other angles. Also, you should be careful with your capitalization.Now we come to the errors that were involved in this experiment!The wavelength was within a error range of ^+_-0.03 cm.Same comment as before, the units need to be consistent. Also, it should be "an error range" not "a error range".the angle was read to the nearest degree so it was really 14^o ^+_-1^o which then makes the d value lower and higher.This is a little confusing. You might want to
bayan
203
This is my report on an experiment that I have done and I really needed the latex codes to generate the equations. I have done the other parts of the report on other PC.
Do they seem to be ok? (the errors, like the max possible value and min possible value)
no help is really needed, rather I want to know what you think of it, any where I can improve or anything I should drop (unnecesary things)
Thank you!
for [tex]\lambda[/tex]
[tex]\lambda =\frac{18.5}{6.5}[/tex]
[tex]\lambda = 2.85 cm[/tex]
This indicates that the apprxmiate wavelength is [tex]2.85 cm[/tex] with a error margin of [tex]^+_-0.03[/tex]
now to find the spacing between the ball bearings we can use the first angle and [tex]Bragg's[/tex] [tex]equation[/tex] to find the other angles.
[tex]n1[/tex]
[tex]1\lambda =2dSin14^o[/tex]
[tex]d=\frac {2.85}{2Sin14^o}[/tex]
[tex]d= 5.89 cm[/tex]
[tex] n2 [/tex]
[tex] \theta=Sin^{-1} \frac {5.7}{11.78}[/tex]
[tex] \theta = 28.9^o [/tex]
for [tex] n3 [/tex]
[tex] \theta= Sin^{-1} \frac {8.55}{11.78} [/tex]
[tex] \theta = 46.5^o [/tex]
for [tex] n4 [/tex]
[tex] \theta = Sin^-1 \frac {11.4}{11.78}[/tex]
[tex]\theta = 75.4^o[/tex]
there is no [tex]n5[/tex] as the equation makes no scence and there is no value for [tex]sin[/tex] grater than [tex]1[/tex]
The wavelength was within a error range of [tex]^+_-0.03 cm[/tex].
the angle was read to the nearest degree so it was really [tex]14^o ^+_-1^o[/tex] which then makes the d value lower and higher.
For example the maximum d is when angle was [tex]14^o-1^o=13^o[/tex]
Now we get the new [tex]d=\frac {2.88}{2sin13^o}[/tex] which is [tex]6.4 cm[/tex]
The minimum value obtainable from these sets of result are as followed.
[tex]d=\frac {2.82}{2sin14^o}[/tex] which is [tex]5.82 cm[/tex]
For [tex]n2[/tex] the angle was [tex]28.9^o[/tex] which could have been altered such that maximum is [tex]\theta = sin^-^1 \frac {5.76}{11.64}[/tex] which is about [tex]29.7^o[/tex] and the minimum value could have been
[tex] \theta = Sin^-^1 \frac {5.64}{12.8}[/tex] in which the angle is about [tex]26.1^o[/tex]
This just repeats until the last value of reflection angle.
I will show that the last angle would still exist even with the big error probability.
For Max [itex]\theta[/itex] the [itex]\theta=2.88[/itex] which results [itex]\theta = sin^{-1} \frac {11.52}{11.64}[/itex] which is [itex]81.8^o[/itex] and for Min the angle is [itex]\theta = sin^{-1} \frac {11.28}{12.8}[/itex] which happens to be about [itex]61.8^o[/itex]
So infact the errors did not have a huge impact on the resultst that we were really interested (which is to find how many ball bearings there is!) but if we were to have a diffrent aim those errors would have made it really hard (for example if we wanted to see what exactly the crystall looks like)
Sorry for the late reply. This thread got lost in the hustle and bustle of our recent upgrade. In case you're still interested, here's what I think of your report.
That second line needs units.
The error margin needs units.
If you want LaTeX to line up with regular HTML text, then you should use the itex tags (inline LaTeX).
[tex]n1[/tex]
In the first line it looks like it should be [itex]n_1[/itex], but I'm not sure because it seems to come from nowhere. Also, [itex]sin[/itex] should not be capitalized. Similar comments for [itex]n_2[/itex] through [itex]n_5[/itex].
Thank you for sharing your report on your experiment and for seeking feedback on it. Overall, your report seems well-written and organized. I appreciate that you have included equations and calculations to support your findings.
One suggestion for improvement would be to provide more details on the experimental setup and procedure. This will help readers understand the context of your results and any potential sources of error. Additionally, it would be beneficial to include a discussion of the sources of error and how they may have affected your results. This will demonstrate a deeper understanding of the experiment and its limitations.
In terms of what can be dropped, I think the section on finding values for other angles may not be necessary as it is already clear that these angles can be calculated using Bragg's equation. However, it may be helpful to mention any discrepancies between the calculated angles and the measured angles, if any.
Overall, your report shows a good understanding of the experiment and its results. Keep up the good work!
What is the purpose of analyzing experimental errors on wavelength and angle measurements?
The purpose of this analysis is to assess the accuracy and precision of the measurements taken during an experiment. By identifying and quantifying the errors associated with the measurements, scientists can determine the reliability of their data and make adjustments to improve the quality of their results.
What are the sources of experimental errors in wavelength and angle measurements?
There are multiple sources of experimental errors, including instrumental errors (such as a misaligned spectrometer or imprecise measuring tools), human errors (such as reading measurements incorrectly or inconsistent handling of samples), and environmental factors (such as temperature and humidity fluctuations).
How are experimental errors quantified in wavelength and angle measurements?
Experimental errors can be quantified using statistical methods such as standard deviation, percent error, and confidence intervals. These calculations help determine the magnitude and significance of the errors and provide a measure of uncertainty in the measurements.
What steps can be taken to minimize experimental errors in wavelength and angle measurements?
To minimize experimental errors, scientists can take several precautions, such as calibrating instruments regularly, using multiple trials to reduce random errors, ensuring proper handling and measurement techniques, and controlling environmental factors as much as possible.
How do experimental errors affect the overall results and conclusions of an experiment?
Experimental errors can have a significant impact on the accuracy and reliability of experimental results. They can lead to incorrect conclusions or make it difficult to detect small effects or patterns in the data. Therefore, it is crucial to identify and minimize experimental errors to ensure the validity of scientific findings.
