What is causing the unexpected behavior in my Darlington pair circuit?
In summary: It seems like it is based on static electricity. When you touch the transistor, you create a spark that causes the current to flow.
jono20
I've built a Darlington pair from 2N2222 NPN transistors on my breadboard, and I find that just my touching of the base lead in the circuit cascades both transistors and let's current flow in the circuit. What's causing this? See the video below for details.
Your video don't work. But my guess is since you put them in darlington, β of 2n2222 is about 100, two of them darlington give 100000. So if your body is charged up to so voltage and touch the base, you provide enough current to make the pair conduct enough to light up the LED. Just a guess.
Think of if you put a cap from the base to ground, just a small 0.1uF. If you apply a small voltage enough to light up the LED, then you remove the voltage. The voltage from the cap will hold the LED on for a while also. Just static charge.
Your body picks up noise which is mainly 60 Hz voltage and your hand applies this voltage to the base of the transistor.
This turns the LED on and off rapidly and you see light from when it is on.
It is similar to the effect you get if you touch the microphone input of an amplifier. In that case, you get a loud burst of a buzzing noise.
This comes from living in a city where mains noise is everywhere.
Is it a result of the DC transformer being plugged into the wall then?
It could be. Any alternating magnetic field, and the nearer it is, the worse, usually.
That seems to be the case. If I completely isolate the circuit and use charged capacitors as the power source, I can no longer light the bulb by touching only the base, I can by touching the base and positive capacitor lead, though.
What is a mystery circuit and why does it need solving?
A mystery circuit is a set of interconnected electronic components whose function or purpose is unknown. It needs solving because understanding its purpose can help improve its design or troubleshoot any problems that may arise.
How do I approach solving a mystery circuit?
The first step is to gather as much information as possible about the circuit, such as its components, connections, and any available documentation. Then, using deductive reasoning and testing, you can analyze the circuit's behavior and gradually understand its function.
What tools and techniques are useful for solving a mystery circuit?
Some useful tools include a multimeter, oscilloscope, and logic analyzer for testing voltage, current, and signal behavior. Techniques such as circuit tracing, schematic analysis, and trial and error can also aid in solving a mystery circuit.
How long does it take to solve a mystery circuit?
The time it takes to solve a mystery circuit can vary greatly depending on the complexity and availability of information. It can take anywhere from a few hours to several weeks or more, depending on the level of expertise and resources available.
What are some common challenges when solving a mystery circuit?
Some common challenges include outdated or incorrect documentation, damaged or faulty components, and complex or unconventional designs. It can also be challenging to troubleshoot circuits with multiple interconnected components and unknown connections.
  • Electrical Engineering
